Old 09-08-2004, 11:58 PM   #1
clarkjw24
I like cheese
clarkjw24's Avatar
What rear axle for 2wd 72 C10 do I need?
As the title says. I don't have a clue. A guy said he needed one but I'm not sure what I'm looking for. I deal mostly with 80s 4wd. Will anything work or is there special perches or spring pads. He wants to do a straight swap with as little headache as possible.
John
clarkjw24 is offline   Reply With Quote
Old 09-09-2004, 12:08 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You need to find out if he has leaf springs or coils.
Old 09-09-2004, 06:15 AM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
You will need a truck 12 bolt, the car ones are different I believe.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 09-09-2004, 01:26 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Something with as little change limits you to 1971 or 72 12 bolt from a similar sprung truck, coil or leaf. 73+ will be leaf only and the spring pads will be in the wrong location(if he has leaf) so they would need to be relocated. You can also use a 1970 truck 12 bolt. It should be the same width as 71-72 but you will need to change the axles out because they are 6 lug. Very simple operation if it has to be done. The earlier 12 bolts were narrower so if you find one and are in doubt, measure backing plate to backing plate to make sure it is the same as the 72 he currently has.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-09-2004, 01:36 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Please correct me if I'm wrong, but a '73-up leaf spring rearend could be swapped into a '72 2wd leaf spring truck by relocating the shock mounts (wrong location and '73-up has staggered shocks) and by adding a bump stop to the rearend ('73-up bumpstop was on frame instead of rearend). I believe '73-up leaf spring perches are at the same width as the earlier 2wd leaf spring trucks (earlier 4wd trucks have a narrower spring pad width).
I'm basing this on my '72 2wd leaf spring truck, my '72 4wd Blazer, and various '73-up 2wd and 4wd trucks I've looked at and measured.
badpeanut is offline   Reply With Quote
Old 09-10-2004, 08:24 AM   #6
dennis111
dennis111's Avatar
I haven't found anyone who has done this swap but I am comtemplating it on my 2wd 68pu. I know that you are working on a 4wd but figure you may get something from the following observations.
I junked a 78' 2wd and kept the rear because the spring pads were exactly the same distance apart as my 68's (42.5" centers, if I recall correctly.) The bumpers and the shock mounts would need some modification. The shock mounts would need to be moved more inboard and one would have to be reversed.
Other deviations I have found is that the 78's pinion "appears" to jut out about an inch more forward, the spring pads themselves are a little wider (2.5" vs 2.25" on my older 68' 2wd-sounds like not a problem on your 4wd), and the brake lines will need a little modification.
Currently torn between locating a 71-72 rear that will bolt right in or doing the mods to the 78'. I would love to know if anyone else has done it.
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 09-10-2004, 02:05 PM   #7
badpeanut
badpeanut's Avatar
dennis111, is the leaf spring rearend in your '68 a GM 12 bolt or a Dana 44? Is it narrower than the '78 like has been stated? Does the width even matter unless one has the need to swap in the old axles to retain a bolt pattern?
I, too, am looking at rearend swaps. My '72 2wd GMC leaf spring truck has a GM 12 bolt, but I've come across a '60-'66 GMC with a leaf spring Dana 44. I don't know that a person could get 5-lug axles for the Dana 44 so it might not be a good option. Short of finding a '71 or '72 rearend, I think a '73-up 12 bolt is the best option. I'd like to hear from anyone who has done it.
