lowering with helper leafs
I have a really nice set of helper leafs to install o my coil rear end. I would also like to use some 2" lowering blocks on the rear the same time I cut the front coils. With lowering the rear end by 2", will I still be able to use the helper leafs?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Member since 2000
can the helper springs be moved up? or the bracket they bolt too?
Resident Curmudgeon
![]() Join Date: Dec 1999
It appears to me that these 2 objectives are discordant. If you alter the mounting point to which the helpers affix to the frame, you'll compomise their load bearing characteristics.
or in downeaster vernacular... 'Aye-yaaa, Ya caaahhhnt get theeeey-ah from heeee-ah" ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
"Ochre Ogre"
I say yes, because you are not changing the position of the actual location of the pads that the helper springs contact. It should be trailing arm, overload bracket, shock bracket, lowering block, axle. Installed this way the only thing that changes is the axle is 2" higher.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
#5 | |
Resident Curmudgeon
Fabricate till you "puke"
I had to think about that one Dubie(me brain hurts now, been running leafs too long!) what da burb said, it will work
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
