09-10-2004, 03:49 PM | #1 |
Axle Code - G86 Posi
I was just at the salvage yard and there was a 1970 3/4 ton 2wd with a locking differential. Glove box code is G86. Does this indicate an axle ratio?
I want a posi for my 4 x 4 and want to switch the carrier only. Also, is it worth $150? Thanks, Dan
1972 K/20 355 c.i.d. sleeper "Circus Wagon" Last edited by kaarazy; 09-10-2004 at 03:57 PM. |
09-10-2004, 04:11 PM | #2 |
G86 is Posi code does not tell the ratio
09-10-2004, 05:26 PM | #3 |
That is a Detroit Locker, not a posi. I would jump on it for $150. Tractech no longer makes them for the Eaton axle. If there was no optional axle ratio listed on the sticker, then it depends on the truck's engine. If it had a 250, 292, or 307, then it will be 4.57 ratio stock, and if it had a 350 it will be 4.11. Good luck.
EDIT: Guess I jumped the gun...if it is a dana 60 rear axle, then it will have a posi...a dana/spicer power lok. if it is the eaton, then what i said above applies.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
09-11-2004, 02:45 AM | #4 |
Axle
Thanks for the replies. It has a small block but not sure what size it is.
There is a sticker on the driver side inside the cab that says sometime about the unit and it was made in Detroit so it is probably a locker. It is the large Eaton axle. Dan Looks like I will go and have them torch out the axle tomorrow!
1972 K/20 355 c.i.d. sleeper "Circus Wagon" |
09-11-2004, 06:16 PM | #5 |
Axle is home
Ok. I went and picked up the axle today and will swap out the carrier tomorrow so I can do some 2 wheel peels. Does anyone know what axle lube weight I should use? Also, seeing as though it is a locker, does it need a friction modifier like a 12 bolt Chevy?
Dan
09-12-2004, 01:17 AM | #6 |
I prefer plain ol 90w for mine, and you do not need anything special for the detroit.
