Old 09-12-2004, 08:55 PM   #1
mr.ed
mr.ed's Avatar
Dash ?
The dash in my blazer has been cut for an aftermarket radio. A friend of mine just gave me a parts pick-up with a uncut dash. How hard is it to change out? Thanks Ed
mr.ed is offline   Reply With Quote
Old 09-12-2004, 09:45 PM   #2
jhow66
jhow66's Avatar
Not bad if you have a welder. Remove the 3 bolts on each side-remove dash pad-cut dash along where holes are-cut new dash in the same place-bolt back in and just tack weld the dash down the line of holes-does not have to be perfect as it will be no see.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-12-2004, 10:12 PM   #3
Gee_Emm
At the sides where it bolts in it might be spot welded there, some are some aren't. It took me a couple hours to get the spot welds undone on mine, you can't get a drill in there, I ended up pealing the metal apart to get the old dash out.
Gee_Emm is offline   Reply With Quote
