4wd to 2wd
hey guys. help me! I have found a good deal on a '77 4x4 stepside. It has a 427 turbo jet and the interior/exterior are in good shape. The only drawback is I am looking for a 2wd cruiser for daily driving. I was curious as to whether I could convert this truck to 2wd. I have a donor truck with front suspension and steering, as well as nearly all other needed parts laying around but I am not sure if a 2wd front suspension can be bolted on. Does anyone know? This is a nice truck but I don't need a 4x4.
Thanks for the insight, Zach P.S. I need a new truck fairly soon, my burb is going to blow soon!!!! |
Professional Grade
Yep, you can convert the frame over
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Thanks for the link! I searched on yahoo and google for info but didn't find anything, I post here and get info in a matter of hours! Thanks a lot! Looks like it will be pretty straightforward since I have a '78 3/4 2wd ton rolling frame sitting out back with a new front suspension and brakes.
thanks again, Zach |
I just posted an update on the conversion Zach.
it is in the thread posted above. Regards, Stacey |
me too. What happened to the search?
loblazer, check out the General Discussion forum.... it has been diasbled as it was causing problems with tying up the site and not allowing members to log in for hours at a time.
