Old 09-12-2004, 03:47 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Vintage intake manifold ID
I posted something on here a week or so ago, asking if there was a way to ID an old intake...
well I FINALLY got numbers/pics of it.
You can see, what apears to be a date code...2-2-61
Just above it, there is a number...9788349...if this number is the ID number, and it comes back as a bad one...I can double check the numbar again after bead blasting it...which I plan on doing if this sucker is worth something.
You can see in the front of the intake, it has the old style oil filler..283/327 style. (I know more than just those motors were so equipped, just those are the ones we all relate to on here) There is also no bolt hole for the later style passenger side mount for the alt. This points out to me it is not a generic type replacement...if GM ever made such an animal. Also notice, for a stock intake, it is a bit of a high rise...a bit taller than my Performer intake that I just got. (Thanks Jamie!) This is a steel intake, and it has the rivited plate in the center underneath to prevent the hot oil from heating up the intake charge.
Any one able to tell me if it might be worth something?
Old 09-12-2004, 03:48 PM   #2
Longhorn Man
Oh, on the first pic...it says GM-1 in between the asumed date code and assumed part number.
Old 09-12-2004, 04:22 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I had one on a 283 power pack engine (factory 4 bbl) that looked like that. I believe it was a 1960 Impala engine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-12-2004, 04:28 PM   #4
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
A few Q's if I might. What sorta advantage is there to running that type of intake with the 4 bbl? I assume it would bolt right up to any 283?
Brian
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 09-12-2004, 04:35 PM   #5
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
3799349 maybe? Thats what I see, but I'm half blind.
62-64 327 full size cars, El Camino, Corvette
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 09-12-2004, 05:52 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Can someone check this for me? It's a 350 intake made for a quadrajet carb. Here's the #'s on it:
3927184, then it says GM1 under that, and T under that.
EDIT: I went ahead and checked some websites and I think it's the original manifold from the 350 that used to be in my truck. Here's where I got the info from:
http://www.prestage.com/community/Te...mbers/316.aspx
It says 1969 but my truck was built in '69 and sold in early '70 so I guess it's the original manifold.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 09-12-2004, 07:31 PM   #7
Longhorn Man
Ok, I just looked again, and the 3799349 is the correct number, and off to the right of that is an 'X'
Something I forgot to post that is on there too, as the intake is mounted on the engine, behinde the carb a little to the drivers side from center...about 1/2 way to the distributor hole...'G 92' is also on there in the same way as the numbers posted in the pics above.
Old 09-12-2004, 07:31 PM   #8
Bowtie67
Bowtie67's Avatar
If you find any value in this intake let me know, I have one sitting upstairs in my garage. I also remember having one of these on a 61 283 sport coupe I had in the military. They used an old carter carb if I remember right. No real performance here but might be valuble to someone wanting correct parts for a restore.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 09-12-2004, 07:32 PM   #9
Longhorn Man
Cool, is there any way to narrow it down a little?
There is also no provisions for a divorced choke on there either.
Old 09-12-2004, 07:36 PM   #10
john
member #16
john's Avatar
I think you are right about the carb. It would be a smaller square bore pattern. Good for resto. John
john is offline   Reply With Quote
Old 09-12-2004, 10:02 PM   #11
Here's what it says about yours:
3799349 4 Brl 62-64 300HP Carter AFB327
RJD
Old 09-12-2004, 10:24 PM   #12
Longhorn Man
Hmm, interesting. From the info given here, and assuming it is off of a 62 becouse of the possible date code, then it could be off of any car in 62 except the Chevy II and the Corvette. Acording to my books, all the other cars were avalible with the 300 horse 327 with an AFB on top.
Old 09-13-2004, 01:24 AM   #13
neonlarry
neonlarry's Avatar
I know where there is one of those I could get for free probably too. lol The whole engine is there actually, but its most lkely rusted into a solid peice.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-13-2004, 09:10 AM   #14
olblue60@aol.com
member
The only #s I can come up with are the same 3799349 carter 4bbl. 62 64,No other #s are close ,but that date? I'm confused? I have a 283 in my 60 sedan delivery and the reason for the "no choke provision" is that on my 1960, there is a piece of 1/4 in tubing that runs from the exhaust manifold to the choke that transmits the heat for the choke spring. No provision on my intake either.
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 09-13-2004, 02:58 PM   #15
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I keep finding basically the same info everywhere:
3799349 4-Brl 62-64 300hp AFB 327
Nothing to put it in an exact application. Post this on a vette board maybe?
67 Short Step
283/TH400/4.11
Old 09-13-2004, 04:19 PM   #16
Longhorn Man
the vette didn't get the 300 horse 327...only the 250 horse. (acording to my chevrolet by the numbers book)
Thanks for the leg work y'all. I apreciate it.
