Old 09-18-2004, 12:11 AM   #1
BobinPA
How to fix a loose column shifter arm?
Just picked up a 72 with a 350 and three-on-the-tree. The problem is the pin that keeps the shifter arm in keeps popping out, and the arm feels loose.
Would simply replacing the pin help, or should the column piece that houses the shifter arm need to be replaced?
Thanks.
BobinPA is offline   Reply With Quote
Old 09-18-2004, 12:21 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
A new pin would prolly fix it.A rollpin might fit in there a little tighter and not pop out.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-18-2004, 12:30 AM   #3
BobinPA
Thanks BC, maybe dump question, but can u tell me what a rollpin is and where I can get one?
Old 09-18-2004, 04:36 AM   #4
74KDD
My dad put in a cotter pin, and it has worked fine for the past 30 years.
KDD
74KDD is offline   Reply With Quote
Old 09-18-2004, 05:55 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is a nylon bushing that goes in the shifte are. You can get it at the dealer for a buck or two. I don't have the p/n right now,but I might be able to produce one for you.
Old 09-18-2004, 04:52 PM   #6
BobinPA
Longhorn man, thanks, if you can get the number it would be appreciated.
Looks like PO used a straight pin (no groves) to hold the handle on. The real problem appears to be the pin hold in the column is larger than it should be. So new question is, can I replace just the column section that the manual shifter handle attachs to, and how difficult is it to replace in the truck?
Thanks again to all.
