Old 09-19-2004, 12:12 AM   #1
Nima
Blue 67
Gasket question:
Hi
I am planning to change my air intake from stock to edlebrook performer series. I also want to change the carb to 4 edlebrook 600 4 bbl. I plan to use felpro gasket for the intake. Do I need to use any sealant/adhesive too?
Thanks for info.
Nima is offline   Reply With Quote
Old 09-19-2004, 12:21 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I always run a small bead of silicon around the water ports,and a thick bead under each end,and throw the rubber gaskets away.Those stupid things always leak.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-19-2004, 01:00 AM   #3
cduster
It is also a good idea to take a punch and go along the valley about every 1/4 inch or so where the rubber or cork gaskets would have been before you lay a thick bead of silicone in there.
Dan
cduster is offline   Reply With Quote
Old 09-19-2004, 01:35 AM   #4
Nima
Blue 67
Thaks for the replies, now another questiion;
Any particular brand of silicon?
Old 09-19-2004, 04:58 AM   #5
1972C10
1972C10's Avatar
I only use silicone across the front and the back of the intake vally.. No punching nessacary Gm didnt start beating the blocks with a chisel when they went to silicone across the intake .
I quit putting silicone around the water ports because i never have any leak and when you do put silicone there the gasket slides around
I suggest using some print-o-seal Mr gasket intake gaskets they are very effective on aluminum intakes Althou i have used plan blue fel pro with great results
And get a little awl or screwdriver and make sure the crack where the heads and vally meet are clean .. i spray mine down with B-12 prior to applying silicone and make sure you get a good bead at that point ..
and i put a small dab on the gasket on the corners after i posistion the gasket onto the heads
I suggest using Red High Temp Silicone Its all i ever use and ive never had it blow out or leak .
1972C10 is offline   Reply With Quote
Old 09-19-2004, 07:40 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I used the Fel-Pro gaskets that Edelbrock recommended when I installed mine. As for the Silicone, Permatex has one specifically for gaskets. Be cautious with silicone sealers. Some will cause metals to corrode, over time.
Member Nr. 2770
