Old 09-20-2004, 06:59 PM   #1
nightmare
nightmare's Avatar
Wanted: Power Steering Bracket
I've got the bottom bracket for a '69 small block, but the other one is shot. Anyone have the top bracket that I would be able to get from them? Please let me know. Thanks
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-20-2004, 09:10 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There is no top and bottom bracket on a small block p/s. The brackets cradle the pump as a unit.
Could you post a picture, or, more details?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-20-2004, 09:21 PM   #3
nightmare
nightmare's Avatar
With the pictures not working correctly, I'll try to explain more. Basically, all I have is the bracket that the pump sits in. I don't have the bracket that puts tension onto the belt. From what I can tell, there are two bolts on the back of the pump, and one on the front. The bottom two (the one in front and one in back are lined up) are the only spot where the pump "sits." Then there is the tension bolt that is up higher on the pump. I don't have the bracket that that bolt goes into.
Mike
67-72 FAQ
Old 09-20-2004, 11:27 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Here's a link to a pic I just took of my 69's power steering bracket, I don't know if it's correct, but it does work with headers. It bolts to the motor mount. Someone else was looking for a bracket for headrs, but I can't find the post.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-21-2004, 12:50 AM   #5
nightmare
nightmare's Avatar
That looks like the one that I'm looking for Fred. Does anyone have that one, and would like to get rid of it?
Mike
67-72 FAQ
Old 09-21-2004, 11:30 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
ttt
Fred
Old 09-22-2004, 07:41 AM   #7
gregbr
Senoir Member
gregbr's Avatar
There is a set on ebay....item # 7923410812. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
