Old 09-25-2004, 10:43 PM   #5
RemoteControl
GM replacement hinges bolt on. They are pretty pricey though.
I am not sure what manual you have been reading but every chevy hinge from about '88 on were welded on and are a pain to replace. Hinge pin and bushings are the only other way the fix a sag, unless the hinge halves have been rubbing together for a long time without a bushiing in between them, then you will have to replace the hinge. I have worked at a GM dealer 15 years. You will need another set of hands to do a bushing/pin R&R unless you have a hydraulic jack with an beam attachment. L8R
PEOPLE THAT THINK THEY KNOW EVERYTHING ARE PARTICULARLY ANNOYING TO THOSE OF US THAT DO !!
Dropped 93 Chevy Std Cab, 454 SS conversion, 20 in Centerlines, Wrap Around Ground Effects
RemoteControl is offline   Reply With Quote
