Old 09-22-2004, 01:13 AM   #1
chevytruckfan
chevytruckfan's Avatar
Brake booster install
I just got a brake booster to upgrade my manual brakes to power. I was just wondering if anyone has done this before and what I need to do. I have the booster, bracket and longer rod. I thought I have seen a post on this before, but I cant find it now even with search working again.
chevytruckfan is offline   Reply With Quote
Old 09-22-2004, 08:36 AM   #2
krue
Designated A-hole!
krue's Avatar
All I had to do was unbolt the M/C from the firewall and pull it out far enough to mount the booster. Just bend the brake lines (don't put a crimp in them) to move the M/C out far enough. Connect the booster to the brake pedal. Be prepared to do some adjusting to get everything right. I had to adjust the rod between the booster and M/C, the rod between the brake pedal and booster and worst of all the stupid brake light switch. Your wire to the brake light will need to be extended also. Hook up the vacuum (good idea to get a new check valve) and enjoy.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-24-2004, 10:47 PM   #3
chevytruckfan
Thanks Krue. Since we don't have rep points anymore heres to you Mr. good advice on the bullitin board poster I didn't see this in the FAQ I so will post with some pics when I get mine done. I don't have time to get after it right now because I am working 7 day weeks right now doing hurricane reconstruction.
Old 09-24-2004, 10:58 PM   #4
krue
Designated A-hole!
krue's Avatar
I didn't have a digital camera when I did mine or I would have wrote it up.
www.daveramsey.com
Old 09-25-2004, 02:00 PM   #5
Bleach
this guy
Bleach's Avatar
I would truly appreciate a write up with pics.......I've got my stuff sitting in a box, but I've had this old house to deal with lately.
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Bleach is offline   Reply With Quote
Old 09-26-2004, 03:25 AM   #6
jmanz69
Careful, they attack...
jmanz69's Avatar
chevytruckfan,
I take it everything made it down to you OK? it should go in pretty easy, but will probably need adjusted a little. The truck it came out of was one that was upgraded to P/B so maybe everything except the brake light switch will line up right. Good Luck
jmanz69
jmanz69 is offline   Reply With Quote
