Air cleaner questions
Originally, when I bought the 85, it came with a 5" stock air cleaner that sat on top of a qjet. I wound up getting ride of the air cleaner but kept the carb. Will this air cleaner fit on square bore carbs too? More specifically, on a holley double pumper and maybe a HolleyStreet avenger.
Yes, I'm still trying to get legal?!?!? Thanks Last edited by 85Silveradoin04; 09-26-2004 at 03:10 PM. |
if it has a drop base then you may need to buy a spacer, but other than that yes it will fit fine.
I have a 14" open element cleaner on my holley 1460 with a drop base on it and it won't clear the parts of the carb, I just went to advance auto and bought a 1" air cleaner spacer which was plastic and it works great. All the 4-bbl carbs for these trucks use the same diameter on top of the carb, so any air cleaner will fit.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
#3 | |
Thanks Destructo. |
