Old 06-18-2002, 11:14 PM   #1
wxman1
Question Dashpad Removal
I'm trying to remove the dashpad from my 69 C-10 pickup.
I removed the 4 screws that are visible from the front.
It seems to want to move a little but something's holding it.
Are there other screws that need to come out?
Does it have clips holding it in place?
My service manual doesn't talk about removing the dashpad
and I don't have an Assembly Manual.
Any help is appreciated!
Jim M.
wxman1 is offline   Reply With Quote
Old 06-18-2002, 11:30 PM   #2
Solver
Solver's Avatar
There are about 8 speed nuts up under the dash that hold the front of dash down. Probably have to remove glove box to get to right ones and easiest if dash bezel is out for left ones.There is one in each of the far corners and Keep in mind there is one lined up with speaker that is hardest to get to. I think they are 3/8 nuts
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 06-18-2002, 11:35 PM   #3
racedvl
racedvl's Avatar
Yea, those back ones are a pain in the arse.
racedvl is offline   Reply With Quote
Old 06-18-2002, 11:49 PM   #4
Rabid
Rabid's Avatar
Good timing with this thread. I've got a dashpad on order and I was also wondering about how to go about removing the old pad.
Rabid is offline   Reply With Quote
Old 06-19-2002, 01:26 AM   #5
Fast68Chevy
Fast68Chevy's Avatar
remove instrument panel and glovebox liner and maybe even radio and ashtray and heater controls even, need all the room you can get, luckily our dashes are basic simple ones., there are 7 studs under dash poking through out of the pad itself, the one on each very tippy tip end are pointing straight forward to front of truck and are a ***** first to remove and then to get out of the dash metal holes to allow you to get the pad up and off dash metal.,
good luck, its a fight!~
Fast68Chevy is offline   Reply With Quote
Old 06-19-2002, 08:00 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Talking
Start practicing standing on your head!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-19-2002, 10:05 AM   #7
johnnyp
Keepin' It Stock
johnnyp's Avatar
I removed mine a while back to paint the dash. I removed the glove box liner, the ashtray, and the radio - all of these are easy to remove. With these items removed it was fairly easy to get to the speed nuts. The hardest one to reach is the one in the corner of the driver's side. It would be easy if the instrument bezel was out, but I didn't want to go to that much trouble.
When I put the pad back on, I never did get the nut in the driver's corner back on, so I just left it off - I can't tell it makes much difference. If I ever take the instrument bezel out, I'll put the nut back on. I found ignition wrenches worked best, because they are small enough to work in the confined space.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 06-20-2002, 06:59 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
To make the one in the driver side corner easier, remove the headlight switch.
I just remove the glove box and speedometer bezel and can get to all the nuts on mine. (no AC)
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-20-2002, 07:54 AM   #9
GREEN70-72
GREEN70-72's Avatar
I JUST HAD MINE WRAPED IN GRAY TWEED. I MADE SURE I LEFT THE SPEED NUT OUT BUY THE RADIO. THAT WAS THE PAIN IN THE @SS FOR ME
GREEN70-72 is offline   Reply With Quote
Old 06-20-2002, 02:25 PM   #10
mt Al
I'd definitely take out the instrument panel, headlight switch, glove box, radio and a/c center bezel if so equipped. These nuts are a bugger, be prepared with lots of bugs bunny bandaids for your knuckles!
While you're at it, you might want to change everything else out that needs changing, its better to do it all at once (windshield wiper, hoses, radio, glove box liner, dash bezel, etc.).
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
