Gmc Vin Can You Help
I was wondering if anyone can help break down thid vin # all i realy need is the year . I am trying to get a title for the truck if anyone has info that will help me get one i would realy appreciate it .
There is a link on the home page. Top of the colomn on the left side.
look at the #s you have on drivers side on cab where door closes it should start with cs or ce start with the c and count 5 spots the fifth one will be the last # in the year your truck is if it is a 7 = 67 8=68 9=69 0=70 1=71 2=72 i hope this will help
oops i see you have a gmc they may be drifferent from chevy
for example "cs148f100043"
"c" = chassis designation c= conventional k = 4 wheel drive "s"=engine designation s= 6 cylinder, e = 8 cylinder "1" gvw range 1=3,900 -5,800 1/2 ton/ 2=5200-7500 3/4 ton/ 3=6600-14000 1ton "4"=model type 4= cab and steside pickup 34=cab and fleetside bed "8" model year 7=1967,8=1968,9=1969,0=1970,1=1971,2=1972 "f"= asembly plant a= atlanta,b=baltimore,p=pontiac,1=oshawa, z=fremont, t=tarrytown, k= kansas city MO, j=janesville, n=norwood, s=st. louis , f=flint "100043"= vechicle number...43rd unit built |
its all about the +6 inches
GMC vins vary by year. You'll have to post the number.
you can leave off the last 4 numbers if you like there really not needed to decode the vin to its year and assembly plant, weight class, etc.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
2A674 Tank Rat
The GMC VINs are the same except the 7th Character should be the year, as far as I know:
1967 = C; 7 for Chevy 1968 = B; 8 for Chevy 1969 = A; 9 for Chevy 1970 = Z for 15 Series; A for 25 - 35 Series; 0 for Chevy 1971 = 1; 1 for Chevy 1972 = 2; 2 for Chevy ![]() ![]()
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
GMC vins are done in about three different manners.
Just post it..I can decode them all.
gmc vin
vin number CS10DZA30522
C= conventional cab 2wd
S= six cyl 1= 1/2 ton OD= wideside-fleetside box Z= Fremont Assembly plant A= 1969 year model You got a 69 GMC 1/2 ton 2wd with a pickup box.
bummer, Rod beat me to the punch.
blood type; Retumbo
here's one
CS10DPB61410 also on my firewall there is written in grease pencil CS1590D306AR4026 just what the %^&* does this mean?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
C= conventinal 2wd cab
S= six cylinder 1= 1/2 ton 0D= fleetside box-wideside P= Pontiac assembly plant B= 1968 is that twice in a day Longhorn Man....lol really I have to control my truckaholic-ism more.
#15 |
CS1590D306AR4026
As for all those other numbers...pretty much they were for the assembly line workers to see what kind of model truck they were building. Basically its a portion of the model number thats usually there... I havent seen one as long as you posted on a truck. It pretty much tells the same information a model number breaks down to. With what you posted it is C=conventional cab S= six cyl 1= 1/2 ton 59= 54 inches from cab to rear axle. Why they used 59 to say 54" is beyond me but if it were a Chev it would be a 09 to say 54" inches. 0D= for the fleetside box for those that had not seen a 59 before...it explains a dimension from cab to rear axle..that way you could know the wheel base... being it a short box regular or longhorn dimension. the rest I dont know, and its usually not there on the cab firewall as far as I have seen. does any of the rest match with your vin, it would seem not as you did post your vin also...has the cab been swapped? Anyone know what the rest means.
#16 |
blood type; Retumbo
it is in fact the original cab as I got it from the original owner. I am having troubles downsizing the pic without losing clarity. I will be @ Shuttermutt's MN meet this wknd if anyone there can help. should I try to keep this firewall when I do my cab stretch? you know, for authenticity.
Todd
#17 | |
Don't say "Oops!", Doctor
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
#18 |
My Mistake.....I'm not trying to lead you into thinking the cab has been swapped...by whats there and written on the firewall it appears authentic to the 68 GMC vin number.
As I wrote before, I have usually only seen what are known as model numbers on the firewall.. its what you have ...but you have additional charcters there which I have not seen before, hence, never bothered to decode them ...yet. If its important info, I probably will find out what they all mean eventually. I still learn new stuff....not full of it yet..lol. Rod authenticity may be considered altered if you strech a cab...lol....anyway it would still be a unique to have firewall marking still there when its all done. Sounds like you have plans for it and thats all good.
#19 |
blood type; Retumbo
the interesting thing is there is no options label in the glovebox.
