What rear end?
I have looked at a 78 Scootsdale pickup parts car and i may buy it. It is an original 5.7 Diesel scootsdale truck with a 12 bolt rearend! Witch gears did these cars have? a standard one on the trucks with 5.7 Diesel?
http://www.moldestuket.com 1971 Mustang Mach-1 429 CJ-R 1973 Mustang Mach-1 289 1975/71 Pontiac Firebird Formula 400 1978 Chevrolet C-10 Fleetside Longbed Scottsdale 1980 Pontiac Phoenix |
It should be on the id sticker in the glove box.
If not check the tag on the diff or the stamp on the casting. This site may help you. www.drivetrain.com Doug |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The majority of diesels I have seen have the 3.08 diff, but as Doug said check the Spec sheet.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
ROCKET POWER!
Mine had 2.76
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
