12 bolt disc brake conversion????
I am in the process of dropping in a posi and 3.73 thanks to some great members here but in the process was going to rebuild the drum brakes. But...... I was wondering if there was a cheap way to convert the 12 bolt to disc. I have done this on 14 bolt rear ends for fairly cheap using stock calipers and homemade brackets (work great too).
does anyone know where I can buy brackets and use 1/2 ton front rotors and calipers. seems fairly easy?? thanks guys Also have to get a new brake booster and master cylinder, so I guess I would need one for four wheel discs (Used the stock one on the 14 bolt rear, seemed to work??)
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
member #16
![]() Join Date: Dec 1999
Here is one using Seville parts that can be found in wrecking yard. John
http://www.classicperform.com/tech_a...kes-trucks.htm Read this post. http://207.44.196.117/vboard/showthread.php3?t=121249
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 09-28-2004 at 05:14 PM. |
thanks john I will check it out
