Old 09-28-2004, 10:04 PM   #1
us111
cabs
hi all,sure this has been talked about but havent been able to find it.I know in 81 they changed the front end,but will a 76 K-10 front clip still bolt up to an 81 or newer cab?? thank you.
us111 is offline   Reply With Quote
Old 09-28-2004, 11:00 PM   #2
rolson1039
yes you have to use the hinges from the genre of nose you use but it will work, and you will need to switch out the wiper set up in the cowl too
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 09-29-2004, 07:28 PM   #3
us111
thank you
THANKS rolson1039,big help for me...
Old 09-29-2004, 09:02 PM   #4
c-1072
cab swap
Yes the cabs will swap i just did one for a guy with a 73 i sold him an 86 cab . You just might hav a few extra holes to cover up . Just for future reference you cant go the other way and try to put an older cab with a newer front clip you will catch hell trying to fit the new higes to the old cab .
c-1072 is offline   Reply With Quote
Old 09-30-2004, 01:42 PM   #5
us111
hinges
thank you c-1072,,, i'm not quiet sure though of what hinges you guys are speaking of??
Old 09-30-2004, 05:05 PM   #6
rolson1039
the newer noses from 81-87 have two piece hinges part of which mounts up on the cowl the older units 73-80 have one piece hinges that bolt to the fender wells. you can use the 73-80 fenders with the newer cab. the worst part of the whole thing with that was sometimes depending on if you use aftermarket fenders is you have to kinda bend the tops out some. The rest of it works well.
Also you use the cab mounts to match your chassis. If you want you can email me at Ctruck1976@aol.com if you have other questions as ive already done this swap and learned alot about these trucks in the process
Old 09-30-2004, 06:43 PM   #7
us111
hinges
rolson,,thanks alot,,really appreciate the help from all of you,,have your address and will certainly mail when i decide which way to go,,again thanks
