Old 09-30-2004, 11:56 AM   #1
71swb4x4
71swb4x4's Avatar
Can I put a 68 cab on my 71? What is different?
What is different on a 68 cab? The only thing I can think of is the parking brake. Aren't they hand brakes on 68 and foot on 71? Is that a bolt in piece or a weld in piece? Can I easily convert the 68 cab to the 71?
Thanks!
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-30-2004, 02:19 PM   #2
StingRay
StingRay's Avatar
I think you will have throttle linkage issues to deal with. The 68 uses a rod and the 71 a cable. If you get the 68 rod and pedal set up with the cab you should be fine. The firewalls are different because of this. If you want to use the one cab as a firewall donor for patch pieces and graft them in you can use the correct throttle and e-brake for the year of your truck. I believe the fuse box is in a slightly different location but is probably still compatable.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-30-2004, 10:47 PM   #3
Rod
Gas tanks different too because of the charcoal canister under hood on 71. Theres a vent tube in the cab I believe also on the 71 for that canister.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-01-2004, 05:40 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Rod is right, and another minor difference, the 71 has a raised mounting point on the cab ceiling for the mirror to mount to, while 67 - 70, & 72 do not have this raised mounting point.
Old 10-01-2004, 06:59 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
if you want I have the complete setup for hand brake from my 68.
price?
all I ask is you give my wife a guilt trip this wknd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
