Who Sells Air Shocks?
Trying to find some air shocks for my 71 2wd, coil sprung truck and can't
![]() I want to be able to tow with this truck and need to be able to "pump up" the rear suspension when thing's get heavy. |
does it have the heavy duth rear springs or the light duty?????
the heavy duty ....the coils are evenly spaced... the light duty are tight in the center and wider on each end http://cgi.msn.ebay.com/ebaymotors/w...e=STRK:MESE:IT ![]() |
Springs
Good to know...mine are light duty.
Wanna sell me those you have listed on e-bay or should I just bid on them? PM sent. Thanks ![]() |
www.autozone.com They sell gabriels.
might also try load lever shocks they have springs around the shock little rough ridding when not loaded though
Advance auto parts have them. Monroes sp
72 CHEYENNE 10 SUPER 468/400/3.73 |
![]() Join Date: Mar 2000
The stock shock brackets aren't strong enough to handle shocks by themselves. Adding suspension load to them is asking for trouble. I have had to replace lower shock brackets a couple of times on my truck in the last dozen years.
Saskatoon, Saskatchewan Canada |
#8 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
maybe those airbags that go in the middle of the coil springs would be better.
Weak Link...
Hadn't thought about that...thanks for the input.
I think I'll be trying the heavy duty springs I just purchased from rage'nrat638 first and see how it handles the loads from there. Next would be the air bags in the coils. (thanks TX Firefighter) Gotta luv the board...ask and you shall receive. ![]() |
On the road
![]() ![]() Join Date: Jan 2004
Another thing that works pretty good if you can find them is the optional overload. It is an eliptical leaf spring that has a bracket and bolts in at the rear of the frame. There is a plate that sandwich's in between the rear end housing and trailing arm and has a rubber bumper. When the truck drops the spring makes contact with the bumper. I used to have a set and they worked pretty good.
Mike |
THEY WILL BE GETTING DROPPED OFF AT FED-X TOMARROW MY FRIEND.....
FELL FREE TO CHECK MY STORE.....I NEED CASH.... ![]() ![]() ![]() I HAVE TON'S OF PARTS LISTED....... ![]() http://stores.ebay.com/RAGENRAT638S-...RUCKPARTS-MORE |
I am a Referee of life.
I think Kingparts has a set of those overload springs.He did a couple weeks ago.You might PM him if you decide to go that way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
