Just got new tires
I just got some new tires some BAJA AT 32 11.50 just wondering what you guys thought on pressure?
I was runnning about 40 pounds all the way around no freeway just around town daily driver.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
I have 35" Procomps on my truck. The pressure that I run them at is 27psi. The tire spec a max of 35 psi, but the tread doesnt contact all the way across the tire evenly. So I lowered it, and my tires have worn perfectly. Play with it alittle to see what suites it best!
'72 K-10 Longbed, 4" Lift, Rancho RS9000 Shocks, Trailmaster Springs(soon to be replaced), 35" Procomp Tires, Freshly Rebuilt 350, TH350, NP205, and More To Come ![]() |
![]() Join Date: Feb 2001
Drive slowly over some wet pavement then look at the wetness on the tread. It should be wet the entire width of the tread.
need pics!!!!
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
I will try and take some soon.
20' Daredevil (Ret)
![]() Join Date: May 2003
40 is way too much IMO - probably should be around 28 give or take a bit. Make several marks across the tread side-to-side with a grease marker or chalk - anything that leaves a visible mark. Then drive around a bit. If inflation is too high, the marks will fade first in the center of the tread - too low, the edges will disappear first. Since the front typically carries more weight than the back, you may want a couple more psi up front.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Right now I am running 28 lbs in the front and 25 in the rear on mine. 35x15.50 super swampers. Actually I think they still have a little much. All tires and trucks are different.
Here are some pics
I would never run less than 30 IMO the sugested psi is 34 and 36 I think they sit good at 39-40 plus I hual stuff in the bed alot and at low psi it will really squat them.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 08-20-2006 at 01:46 PM. |
#9 | |
20' Daredevil (Ret)
No more
Nice Tires. My Sport Kings require 50 psi. What type of rims are thoughs. I like them.
1976 Chevy K10 CheyenneTrue Duals with glasspacks and cutouts, Blacked out tails, Rockford Fosgate H/U with 2 Sony Xplode 6x9s and 2 8" MTX Subs with a Alpine Amp. New front clip in primer. For Sale $2000 obo |
I think american racing the PO did not take care of them and I have been trying to clean them up.
No more
Well they look great in the pics!
Yes they do look rather good in the pics not as good in person.
