Old 10-02-2004, 12:16 PM   #1
raggedjim
raggedjim's Avatar
Removing rocker boxes
What's the best way to remove the rocker box from the inside channel? It would make replacing my panels easier and give me the chance to evaluate rust better. It looks like there are welds inside the oblong holes? Grind 'em, chisel, or both?
Thanks, Roger
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is online now   Reply With Quote
Old 10-02-2004, 01:48 PM   #2
Alexis
Member since 2000
Alexis's Avatar
there's some welds on the front side too, towards the wheel well. Grind carefully cause you don't want to cut into the support brace. Goodluck
Alexis is offline   Reply With Quote
Old 10-02-2004, 11:53 PM   #3
orangeuavol
GO VOLS!
orangeuavol's Avatar
Just took out my driver's side box. Its a lot easier if you have to cut your floor pan out. I used a combination of grinding w/ a 3" air cutoff tool, reciprocating saw to cut the welds where I could get inbetween the support brace and box, and a sharp chisel. Good luck.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 10-03-2004, 04:31 AM   #4
Blue Beard
Blue Beard's Avatar
If they are spot welds, I believe Eastwood has a tool for cutting them.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-03-2004, 03:26 PM   #5
71RestoRod
71RestoRod's Avatar
They're not spot welds... more like stitch welds. I had good luck getting mine off with a 4" grinder and an air chisel. I had to jack the front of the tub off of the frame somewhat to get access to everything.
71RestoRod is offline   Reply With Quote
Old 10-05-2004, 12:36 PM   #6
raggedjim
raggedjim's Avatar
Thanks guys, sounds like fun...
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-05-2004, 12:49 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Make sure the top is on or you put in some bracing to hold the body rigid.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
