Now the others dig........
![]() Join Date: May 2002
Removing Steering Column!!!!!!
OK.....so how do I remove the steering column, loosen a few bolts, twist and turn and it's out of there??? help me out guys!!!!
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
there is some bolts that connect it to the steering box,bolts that hold it to the dash and bolts that hold it to the firewall,take all these out,unplug the neutral safty switch,and youll have to wiggle it out,it wont come straight out,helps if you have 2 people and an impact....
SC ![]() |
An Impact????
i just did mine. there is a bracket with 2 bolts under the dash holding the column in place. there is another bracket that bolts to the floor of the truck where the column goes through. there is a small bracket that compresses on the firewall side. the last one is 2 bolts that hold it to the steering box. my truck is a standard, so i didn't have to worry about the shifter linkage. a socket and a wrench is all u need, and maybe a little wd-40.
"All Corvettes are red. The rest are mistakes." - John Heinricy Last edited by old_truck1969; 06-22-2002 at 01:51 PM. |
