Old 10-08-2004, 02:04 PM   #1
flip66
flip66's Avatar
Bleeding brakes
I Need to know of a good way to bleed brakes with one person. I have heard of using a vacuume pump but have never tried it.
flip66 is offline   Reply With Quote
Old 10-08-2004, 02:10 PM   #2
Yukon Jack
Yukon Jack's Avatar
I just got done getting the miscellaneous parts to build a power bleeder - ought to be very handy!
http://www.arkansaspontiacs.org/tech...er%20story.htm
http://www.bmw-m.net/TechProc/bleeder.htm
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-08-2004, 02:24 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Looks like a good idea. I'd suggest maybe using a much thicker piece of metal instead of the 1/8" that he used. A piece of 1/4" thick steel plate for example wouldn't flex when using a c-clamp like shown. Also, I'd use a rubber gasket instead of cork.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-08-2004, 02:30 PM   #4
Yukon Jack
Yukon Jack's Avatar
Yep, those are the changes I am doing too.
Old 10-14-2004, 05:04 PM   #5
flip66
flip66's Avatar
After you apply the presser what do you do? Open the bleeders one at a time, do have to hold the pedal down.
Old 10-14-2004, 05:14 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by flip66
after you apply the prusser what do you do. Open the bleeders one at a time, do have to hold the pedal down.
I'D LIKE TO BUY A VOWEL
JJ FLIP 66, MY SPELLING SUCKS :p
I NEED TO KNOW THIS ALSO
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-14-2004, 05:26 PM   #7
flip66
flip66's Avatar
Need spell check on here
Old 10-14-2004, 06:05 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I used a vacume pump on my blazer. It worked good. I still did it the old fashion way with two people, to check my work. No air at all. Works good when your steel line are completely empty. BUT,... I would still check them with two people. I worry too much!
Keith
Convert to disc brakes.
Old 10-14-2004, 07:09 PM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I like the speed bleeders myself. I have them in most of my cars/trucks now. Just open the valve a bit and pump the pedal all you want. When done, close the valve and your done.
They have a check ball in them so fluid goes out but air cannot come back in on the upstroke.
Available in the HELP section of most auto parts stores and also made by Russell company.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-14-2004, 08:04 PM   #10
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yup the speed bleeders is the only way to go,IMO.I have had no success bleeding brakes by myself without them.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
