10-09-2004, 02:42 PM | #1 |
Heater Core Question
I've got a leak inside the cab of my '72 Fleetside. It has A/C also. The leak (anti-freeze leak) is coming from underneath the dash where all of the heater/AC boxes are. Would this most likely be a heater core leak or what? How do you get to the heater core? Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
10-09-2004, 02:54 PM | #2 | |
Don't say "Oops!", Doctor
Replacing the core on an A/C truck is a bit more of a pain. It helps to have a buddy that can help you get stuff aligned and whatnot, but it's not absolutely necessary. It's been a while since I've done it, but IIRC you'll have to disconnect the hoses, pull the glovebox liner, take out the heater box, swap the core and then put it all back together. There are some good threads on the subject here, here, here, here and here. Good luck!
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
10-09-2004, 03:53 PM | #3 |
Thanks Mutt! Those links really helped a lot. I tried to do a search, but couldn't get anything like that to come up. Appreciate it much.
10-09-2004, 04:13 PM | #4 |
No problem, Ron!
10-09-2004, 08:21 PM | #5 |
Lovin' Life in Miss.!
It also helps to go ahead and drop the passenger fenderwell.
The truck... you hear that? No really, you did hear that?!!! |
