Old 10-10-2004, 12:31 AM   #1
krazy_texan
krazy_texan's Avatar
more gas gauge woes
i cannot seem to figure out what is wrong with my gas gauge, i have checked all the grounds on the dash and i have traced the wire from the sender to the fuse block and my needle is points straight down when i unplug the wire and when i plug it in it points to the end of the the first semi cirle thing like it has a full tank but in the wrong position if you catch my drift, i am in really bad need of this as i have to make a fairly long trip in the truck soon and dont want to be doing any walking at all.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-10-2004, 12:37 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I made if from Tx to Ohio and back with no guage...and no speedo. I had to keep track of miles from the mile markers.
If your guage is pointing at the 6 o'clock position...then I'm thinkin your guage is toast...or the needle has been removed and re-installed wrong.
Old 10-10-2004, 12:39 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Not a chance it used to have dual tanks,and one has been removed,but the switch still installed is there?
That's what was wrong with our wrecker.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-10-2004, 08:03 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It shouldn't be a gauge problem.
I gave him a known working gas guage yesterday. I took the gauge out of the old instrument cluster from my 70. It worked right when pulled.
Jake, is it doing the exact same thing with the new gauge as the old guage?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-10-2004, 08:17 AM   #5
curbyk
69 C-10 project
curbyk's Avatar
This may not be any use but while wee were looking into changing the sending unit on my 69 (inconsistant readings) we noticed the pick-up line was not secure in the mounting plate (I think this grounds the sending unit) took it out and spot welded the tube to the plate readings were fine (until I broke it loose again)
Hope it helps, and good luck
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 10-10-2004, 08:52 AM   #6
jef5150
Inline 69
jef5150's Avatar
2 sending units?
i dont know how your aux tank was set up, factory or not,,,,but did the tank that you removed have its own "seperate" sending unit? if so, what did you do with the wiring? you may have an open circuit to your fuel gauge, just a thought jeff
jef5150 is offline   Reply With Quote
Old 10-10-2004, 09:36 AM   #7
cdowns
cdowns's Avatar
the nice thing about have a bed on a pickup is you can put a gascan in it
Old 10-10-2004, 10:47 AM   #8
guyryan100
guyryan100's Avatar
Just pack a yardstick and a 3gal can of gas and you'll all set. That way you won't have any gauges distracting you while you drive.
guyryan100 is offline   Reply With Quote
Old 10-10-2004, 09:59 PM   #9
jimfulco
My Suburban has the 3:00 gas gauge, & it gets right at 300 miles per tank of gas, so I try to remember to fill up every time it turns over an even 200 miles. And there's a 2.5gal. jerry can of gas in the back 'cause sometimes I forget.
jimfulco is offline   Reply With Quote
Old 10-10-2004, 11:29 PM   #10
Brainchild
Brainchild's Avatar
The ol gas can in the bed works,but friday I was in the middle of a hiway,2 lanes,and no shoulder to pull over on pouring gas in while speeding semis flew around me It's a little nerve wrecking.A working gauge is better
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
