10-09-2004, 07:42 PM | #1 |
67-72 Addict!
How do you remove the door latch assembly?
I need to buy and replace a door latch assembly for a passenger door but I don't know how to remove the old one. I removed the 3 screws on the end of the door but don't know how to get the unit past the window channel. Any help would be appreciated. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-09-2004, 09:00 PM | #2 |
Merciless Butcher
Unbolt the weatherstrtip channel ( two 1/4-20 phillips head screws under the door panel and one 7/16" head 1/4 20 bolt on the outside of the door shell. Pull it forward a little bit. It will give you the room you need to get it out. Tip: Re-attach the actuator rods to the new door latch assy BEFORE you bolt it in place. It's a real pain to try and connect them when it's bolted in place.
Your Bought And Sold....I Got Your Soul! |
10-09-2004, 11:56 PM | #3 |
67-72 Addict!
Thanks. I'll give it a shot tomorrow. I remember seeing 2 screws but don't recall seeing the bolt.
10-10-2004, 08:44 AM | #4 |
The bolt is a phillips screw like the others but has a larger flat washer and not the star washer. be careful with the linkage clips they get lost or broken easily.
Rest in Peace Ed. Thanks for all the good times. |
10-10-2004, 02:22 PM | #5 |
Merciless Butcher
Mothertruckers is right......The bolt on the outside of the door shell IS a phillips head with a washer attached....Sorry for the bad info.
10-10-2004, 07:43 PM | #6 |
67-72 Addict!
Thanks guys. So far I removed the 3 phillips screws. Does the linkage rod just pop up out of the clips?. Ed, I PM'd you about the latch. I hope you got it because I need it ASAP!
