10-01-2004, 06:01 PM | #1 |
18436572
I will pay for this info (70 C/10)
Having no luck (except for one helpful comment) on this problem, I will send $10 Paypal to anyone who can give me an understandable schematic of:
70 C/10 Wiring for stock 2 speed wipers from input at the wiper switch to the connectors to the motor. Basically, I have the connectors going into the wiper motor in a box. Since the motor is mounted, I think there are 3 places to plug in. Hard to tell. I have the wiper switch in that box. I believe the dark blue wire (center one of the 3) feeds power into the switch. That leaves 2 output connectors there. I need to know how to wire it up. Thanks, Paul |
10-01-2004, 06:04 PM | #2 |
Not sure if this helps:
10-01-2004, 06:05 PM | #3 |
No picture attached?
10-01-2004, 06:09 PM | #4 |
i fail to see how a taillight wiring diagram is going to help his wipers
10-01-2004, 06:12 PM | #5 | |
10-01-2004, 06:18 PM | #6 | |
10-01-2004, 06:43 PM | #7 |
OK looking at the wiper switch youve got 3terminals in line 2close to each the other off by itself the lonely terminal gets ltblue the middle dkblue the other outside one is blackie
now lookin at the wiper and washer assy on the back there's 2 terminals dark blue on top then there's a yellow that comes from the fuse box with 2 plugs 1 goes on the bottom ,then on the right side of the pump there's 3termilals from back to front first goes blakie then lt blue then yellow if this makes sence to you and it gets your wipers runnin send the $10 to josh for board upkeep
10-01-2004, 06:47 PM | #8 |
Watch out for your cornhole !
Someone give him the info he wants and make him send the 10 bucks to Josh to support this place instead.
10-01-2004, 06:58 PM | #9 | |
10-01-2004, 06:59 PM | #10 |
I am looking for the cab schematic I had...
That was my plan, to send the money to Josh. |
10-01-2004, 07:18 PM | #11 |
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 10-01-2004 at 07:20 PM. |
10-10-2004, 08:52 PM | #12 |
18436572
Thanks CDowns!
Sorry I didn't get back sooner. |
10-10-2004, 10:42 PM | #13 |
blood type; Retumbo
FYI, the switch grounds the ckt. & supplies power for washer.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
