Old 10-10-2004, 11:32 PM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
door adjustments
I already know te answer I think,just looking for an easier way to do it.
I need to loosen the top hinge at the post,and let it slide back 1/8 of an inch to get the door lined up.Is there an easier way than taking the door or fender off?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-11-2004, 07:33 AM   #2
JimKshortstep4x4
Smile
We machined stainless steel shims 1/16" and 1/8" thick, slotted to clear the bolts when slid into place. The shims work very well and are easy to install as you just loosen the hinge to door bolts and insert. (Sometimes the hinge will not move as far as you need).
I am not sure if shims are available, but it is something to consider.
Jim
Old 10-11-2004, 07:44 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
You should be able to get to the bolts with the right wrench and patience. I replace hinges once (one at time) without removing the door or fender. That was really tricky to get the bolts all the way out and then get them started back in again but I did it. If I remember correctly, the bottom one was the hardest.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-11-2004, 08:51 AM   #4
Brainchild
Brainchild's Avatar
Well I don't have to remove them,just adjust the door alignment.Someone else has already swapped the hinges.There sure isn't a lot ofroom in there for wrenches
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-11-2004, 10:58 AM   #5
JimKshortstep4x4
Smile
I use a Snap-On "S" shaped wrench to get to the bolts, but the wrenches
are rather pricey so I suggested shimming as an option. They are still available from Snap-On and I can post the number of the wrench if you want to go that way.
Jim
