Old 10-11-2004, 01:45 PM   #1
Burt4x4
Burt4x4's Avatar
Talking BBC is in>>>Pics>>
Hello Everyone, a while back I was here asking about adapting a 73+ engine crossmember to my 72 K5 for my SBC to BBC swap. Well I did it and thought I would share some pics..they are kinda dark, sorry. TOo much black paint...
Cain't wait to drive my K5 again
The Xmember was kinda tuff to get in and lined up but it did fit. Now I will beable to remove the oil pan without lifting the engine
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-11-2004, 02:36 PM   #2
Yukon Jack
Yukon Jack's Avatar
You know I'm a droolin'!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-11-2004, 03:22 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
DAMN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-11-2004, 03:23 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Nice! Did you have any firewall problems or did the cross member solve that problem?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-11-2004, 04:04 PM   #5
Burt4x4
Burt4x4's Avatar
I did have to bang bang on the firewall a lil bit, but not too bad. The crossmembers main function is to allow the oil pan to be dropped with out moving the engine. Well that and the ORD engine mounts work too
Sooooon...
Old 10-11-2004, 04:46 PM   #6
Yukon Jack
Yukon Jack's Avatar
Burt, can you get a close up pic from the side showing the frame and engine so I can get an idea of how high your engine is sitting? I'm wondering if the new crossmember your using allows the engine to sit lower than if you had used your stock crossmember and mounts. I just happen to now have a crossmember from a 78 4x4 that I could use if that would help my situation, I definitely want to drop my cab down a bit.
Old 10-11-2004, 05:39 PM   #7
Burt4x4
Burt4x4's Avatar
Yup sure can, well I just have to remember once I leave work! hahahaha
I will try to get some better lighting too, so the black doesn't all blend together.
I'll try to post up tonight, again as long as I remember...getting old you know
Burt
Old 10-12-2004, 10:39 AM   #8
Burt4x4
Burt4x4's Avatar
Thought I would just post them up here...
So much fun
Old 10-12-2004, 09:53 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn nice set-up ...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-13-2004, 12:08 AM   #10
cheyenne10
cheyenne10's Avatar
Looking Good
I'm not familiar with your fuel delivery system. Can you explain type and requirements as well as expected gains over stock quadrajet to a rookie?
Bob
cheyenne10 is offline   Reply With Quote
Old 10-13-2004, 11:10 AM   #11
Burt4x4
Burt4x4's Avatar
Hey Cheyenne10, What you see there is EdelBrock Multi-Point Fuel Injection.
The intake comes complete with everything needed to convert a carbed rig into FI. This unit comes with a hand held controll box so no need for a laptop to tune it. I hear tuning is or can be a pain...I guess I'm gonna find out. But like everything once it's set right then time to ROCK!!
Oh ya the version I got in the Performer type(idel to 5500) not the high reving RPM version.
This rat was built for all lowend torque, yer basic stump puller
Old 10-13-2004, 12:35 PM   #12
71jimmy
71jimmy's Avatar
That FI looks sick. I may also go that way when I rebuild my motor. One thing I'm curiuos about, do you need to build the motor differently for FI versus carb?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-13-2004, 02:02 PM   #13
Burt4x4
Burt4x4's Avatar
Well yes and no. FI does like higher compressions but you can bolt this set to an orginally carbed engine with no changes. Edelbrock will need to know the cam specs inoreder to burn the chip that goes in the computer to run the FI.
This 454 was built around the MPFI intake. The whole engine was built to the specs for lowend torque & fuel injection. CompCams recomended the cam grind to match the lowend torque and fuel injection. I ended up with at least 9:1.1compression(engine guy said with the oversized valves he used will increase the compresion simply due to there size reducing the chamber volume..or something like that hahahaa. This is my first build up so I am still learning all the gearhead talk and stuff
Old 10-13-2004, 07:28 PM   #14
71jimmy
71jimmy's Avatar
Ok, so I better decide bt FI or Carb before I start the build. I'm thinking along the same lines as you, more torque, but will rebuild my 350. Thanks
Old 10-13-2004, 09:35 PM   #15
jamie72
jamie72's Avatar
thats too damn nice!!!
so what will the fi setup cost a guy?? i`d love to do that to my next truck prodject..
keep us posted!
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 10-14-2004, 12:47 PM   #16
Burt4x4
Burt4x4's Avatar
I got it from summit racing
http://store.summitracing.com/partde...4925172+302645
Thanks for the comments
Old 10-14-2004, 01:08 PM   #17
cheyenne10
cheyenne10's Avatar
sounds awesome
Some day I guess. At $2500 for fuel delivery I'm out though. Glad I asked before I started dreaming too much!!
Bob
Old 10-14-2004, 09:05 PM   #18
Big J
Its lookin' like a Blazer!
Big J's Avatar
Thats one of the coolest setups that I've seen in a long time, and its not even done. Ya have to keep the pics comin', nice work.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 10-14-2004, 11:41 PM   #19
teamharvey
teamharvey's Avatar
Burt, I would love to sneak by sometime and take a closer look.
Bret
teamharvey is offline   Reply With Quote
Old 10-15-2004, 10:09 AM   #20
Burt4x4
Burt4x4's Avatar
Sure comon by...I should be home this weekend.
Old 10-20-2004, 01:49 AM   #21
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Burt, that BBC is sweet!!!
I'm gonna have to come, and check it out.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 10-20-2004, 08:50 AM   #22
Trifelynn
Trifelynn's Avatar
Lol
I didn't even see you guys were in my home towns...Turlock, Modesto...
haha.
I am actually from Hughson, Ca...but my parents now live in Modesto.
Where are you guys at?
My parents live back by Palendale, over by Big Valley Church(that is where they go to church)
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 10-20-2004, 11:14 AM   #23
Burt4x4
Burt4x4's Avatar
haha.
Right there is were I am also
Well Snyder not Palendale, same area. I am in the Dutch Hallow area, not the brand new homes. My kids just started going to the new elementary school that was just built right there on Snyder. We ahve been there for almost 2yrs. We use to live in Salida, East side by the 76 station.
You can see us on my wife's web site
www.lisaburt.com
She is a RealEstate agent in Modesto for about 6yrs now.
Thanks for all the great comments fellas. I will share more pics down the road when I get the K5 put back together
Later
Burt
Old 10-20-2004, 11:20 AM   #24
Trifelynn
Trifelynn's Avatar
LOL, you are like two minutes from my parents.
They live at the corner of Bangs and Carver...
Small world..
My parents work at the Save Mart Main office at Bangs Standiford and Carver
Last name Endres
If it rings a bell...
What is your last name?
My parents might know you
Old 10-20-2004, 11:31 AM   #25
Burt4x4
Burt4x4's Avatar
hahah yup small world.
Burt is my last name, Steve is my first
My wife's family is native to the area I am from Auburn, up pass Sacramento on Hwy 80. Her familys name is Olmo, mostly Ripon/Escalon areas.
I am near Snyder and Presscott
From your profile you are on the East coast now, you move out there for work? Come back to Cali and we can go wheelin
Burt
