Old 10-11-2004, 09:58 PM   #1
SteedaLX
Can I do this?
First some background info. The hot wire to the coil was losing power after the truck started, which caused it to die. The guy who I took it to spliced into another hot under the hood and ran that wire to the coil hot, which works. The problem is when the switch is on, the connection(where he spliced into the other hot) gets hot and smokes. It has begun to burn the wire in to. Not good.
Can I just run a hot wire from the fuse panel to the coil? If not what can I do?
1971 GMC Jimmy
6" Superlift w/ 35" tires
Chattanooga, TN
SteedaLX is offline   Reply With Quote
Old 10-11-2004, 10:42 PM   #2
jhow66
jhow66's Avatar
Points or HEI?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-12-2004, 08:27 AM   #3
SteedaLX
Points
1971 GMC Jimmy
Chattanooga, TN
Old 10-12-2004, 10:07 AM   #4
SteedaLX
Well from what I read at CK5 I can not run a direct wire. Does anybody have a diagram of the wiring for the coil?
1971 GMC Jimmy
Chattanooga, TN
Old 10-12-2004, 11:02 AM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Here are wire diagrams. http://www.geocities.com/chevroletc1070/wiringdias.html
The PO of my '69 truck did something similar, but he put in a toggle switch to start the truck and by-passed the neutral safety switch. I had to put the the key in the run position and hit the toggle switch. Eventually, it burned up the hot wire. I re-wired it according to the diargams. I bought a new pigtail for the ignition plug and a new switch. I haven't had a problem since.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
