Old 10-13-2004, 06:56 PM   #1
PHOENIX
New exhaust - now have backfire
I put on new headers, new y-pipe, new cat and new muffler (aero chamber).
From y-pipe back its a single 3" pipe all the way out. Cat is in stock location, muffler is about 1'-6" in front of rear axle, pipe goes over rear axle and out behind drivers tire like stock.
When I rev it up like 3000 rpm + and let off the throttle there is a few back fires right before it returns to idle speed. What causes this?
Is this carb settings, timing issue or is this what I should expect with this higher flowing exhaust setup?
I will try to get a video or sound clip up later to show you what I am talking about.
Thanks!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-13-2004, 10:27 PM   #2
Tom
driving is in my blood
Tom's Avatar
Better flow = leaner mixture. Play with the carb a little and you should be fine. I know short exausts like mine [exit before rear wheels] can cause some poping but yours wont.
Old 10-15-2004, 01:51 AM   #3
PHOENIX
I definately need to adjust the carb.
I am pretty sure I found the problem.
These headers have the air tubes and I have brand new air pump check valves installed. But not the hoses from the air pump diverter valve to the check valves. I need to buy new hoses that is why they are not on. Well I was wondering about it, so I put a cap on each valves and rev'd up the truck. No more popping sound at all. Sounds pretty good too, I might drive it to work tomorrow, but I dont know cause my tags expired. I have to go to emissions
The reason I didnt suspect this at first is because the check valves were not allowing any outward flow. Now they they are letting out a very slight amount. Not enough to over power the air being pumped in from the smog pump though.
Old 10-16-2004, 09:46 AM   #4
Mike76251
I think you have it nailed.
Most check valves do leak a little and it doesn't take much leakage to hear it rather loudly.
Not that I would know about smog pumps and divertor valves and cats and emission testing and things like that .
Mike76251 is offline   Reply With Quote
Old 10-16-2004, 11:17 AM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
LOL, my dad said he disconnected all that smog stuff (except the cat) ages ago. Most places around here don't even look for a cat.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
