Old 10-17-2004, 12:05 AM   #1
71Longbed
Not Mine But A beauty
71Longbed's Avatar
Electrical proplems again!!
hello all truck was runing fine after last times grounding straps however decided to put in a cd player installed it up heard it for a while after that i turned the truck on and it ran for a bit after it shut off i thought weird then turned it back on and sure enopugh it ran a bit and turned off ok charged the battery uyp started it up in the morning again ran for a few minutes then shut off again is the alternator not recharging the batter or is the altornator not enough for my 500 amp starter? help some one plz last Topic discussed about this here http://207.44.196.117/vboard/showthr...trical+problem
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 10-17-2004, 12:54 AM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I reread your prior post and don't quite follow how you have your dizzy wired up with the diode. Suspect something there. Someone suggested ditching your points and goin HEI and I agree.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-17-2004, 01:25 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'd toss an HEI in there,and run a new wire from the fuse box to the dizzy.Don not use the diode,problem should be fixed.
If you still have hte points in there,you could swap out the condenser,that's how they act when they're bad.The HEI would be by far the best deal.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-17-2004, 01:41 AM   #4
71Longbed
71Longbed's Avatar
Im assuming that by dizzy you mean starter? the starter is wired as follows battery to bat terminal and then i have a brown colr wire wich i dont know where it leads but its there then its spliced with a diode between the brown and in comes the r cable from the cab on the other side of diode i wouldnt know why you need the diode but in the starter instructions it tells me to use it if the strter doesnt have a R terminal this diode leads to the Plus side of the CoiL
Old 10-17-2004, 02:06 AM   #5
chickenwing
Sorry......... Dizzy=Distributer. I'd hafta check out your stuff in person across a diagram to figure it out. I don't know the purpose of the diode in that circuit. Maybe it's a resistor? That would make since to drop voltage prior to points if there is no resistor wire being used. Condensors purpose is to prevent arcing in points to prolong their life. Am unable to confirm or deny that a bad condensor will cause a run-on condition.
Old 10-17-2004, 09:02 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
his diode thing is OK, There is no R terminal, so he has the yellow coil wire on the starter wire (should be purple) and when the key is turned, the purple is powered, and the yellow is stacked on it so it gets powered too. Then, when he lets off the key, the resistor wire tekes over, but it'll send the 9 volts down the yellow wire. The diode...a one way check valve if you will, prevents the 9-ish volte from hitting the S terminal. And prevents the starter from staying engaged.
As for your stereo...does it stay on at low volumes, and shuts off when you have it cranked?
Old 10-17-2004, 03:32 PM   #7
chickenwing
I understand now, Longhorn. Thanks. Man, I'm still tryin to figure out what the symptoms are! I think he is either having a run on condition that happened to act up after his stereo install or his motor is dying shortly after he starts it. Am I just dense?
Old 10-17-2004, 04:10 PM   #8
Longhorn Man
Is the engine stalling, or is the radio shutting off on it's own, or does the engine cough and fart and sputter when you turn off the engine?
Old 10-17-2004, 10:51 PM   #9
71Longbed
71Longbed's Avatar
wut happens is when i turn on the truck the lights on the stereo go haywire the truck runs for a little bit then shuts off is it the alternator is too weak?
Old 10-17-2004, 11:00 PM   #10
Brainchild
Brainchild's Avatar
Could be,what kind of system do you have? How many amps,ect.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-17-2004, 11:03 PM   #11
71Longbed
71Longbed's Avatar
im only running a head unit and a 6 inch sub i think the starters is the one pulling my battery dry the starter is 500 amps my head unit is only 180 amps i find it surprising that i cant pull a head unit without my truck shutting off
Old 10-17-2004, 11:19 PM   #12
Longhorn Man
does it sputter and die, or does it shut off as if you turned the key to the off position?
Old 10-17-2004, 11:25 PM   #13
71Longbed
71Longbed's Avatar
it just shuts off
Old 10-17-2004, 11:41 PM   #14
chickenwing
So your stereo draws 180 amps continuous???
Old 10-18-2004, 12:36 AM   #15
71Longbed
71Longbed's Avatar
oops i meant watts
Old 10-18-2004, 01:17 AM   #16
Brainchild
Brainchild's Avatar
That shouldn't be a problem.I'm running a Deck,150 watt amp and have no problems.
The starter shouldn't be pulling anything once the truck is running.
Does the truck run with the stereo off?
Where are you getting power for the stereo?
And is there power to the coil/dizzy the entire time?
Someone holding a probe tester on the positive side of the coil while th truck is running will answer the last question
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-18-2004, 04:17 AM   #17
71Longbed
71Longbed's Avatar
pulling the neck from where the old one was the truck runs with stereo off and stereo runs with truck off when i turn it on its as if theres not enough power to run truck and cd player because the cd player's light flicker
Old 10-18-2004, 04:54 AM   #18
Brainchild
Brainchild's Avatar
Have you tried to run a new power source for the stereo.Maybe it's a bad terminal in the fuse block or something
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-18-2004, 08:05 AM   #19
chickenwing
What did you tap into for power to stereo? Wich fuse or what color wire?
Old 10-18-2004, 04:24 PM   #20
71Longbed
71Longbed's Avatar
ok i tried it out with the radio on the truck just shuts off after a little while of being on and radio stays on turned off radio and tried to drive the truck but it just drove a little bit then bogged doen and turned off
Old 10-18-2004, 07:39 PM   #21
Brainchild
Brainchild's Avatar
Do you still have the pointys in it? If so check hte condenser.It the little silver cylinder inside the distributor.Change it out,it's a couple of buck,see if that helps.
If you're using the HEI setup,could be module going bad,or you need to run a power wire to the distributor.
Also pull th cap,and see if the wires running into the distributor are shorting out somewhere along the way.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
