Old 10-18-2004, 09:14 PM   #1
crawdad
crawdad's Avatar
Question Dumb question about HEI
The distributor that was in my '72 when I bought it has the coil in the distributor cap. Is that one of the HEI units? Which of the HEI units is best, the coil in cap type, or the one with a separate coil? Can the coil in cap unit be changed to a separate coil type by replacing the cap with a different type?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 10-18-2004, 09:20 PM   #2
Russell
Professional Grade
Russell's Avatar
The in cap HEI units are extremely good units, much cleaner install too, in my opinion
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-18-2004, 09:27 PM   #3
djracer
djracer's Avatar
You can get a convert a cap to use a seperate coil!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-18-2004, 10:01 PM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
You can also get aftermarket incap installs too,and move up to an accell or mallory,or whatever coil.Like This one
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-18-2004, 10:11 PM   #5
crawdad
crawdad's Avatar
All good information. Thank you much.
