Old 10-19-2004, 04:02 AM   #1
lost wages
lost wages's Avatar
Question looking for info on sway bars
on my truck i have a 68 frame with a 77 front crossmember, it is also bagged, after driving it a few times i realize i need a sway bar bad. will a bar off a 67-72 work or with the different front a arms from the 77 do i need something different? also, what problems will i run into beings as it is bagged? anyone have a similar setup?
lost wages is offline   Reply With Quote
Old 10-19-2004, 05:04 AM   #2
Lippyp
English Chevy Owner
Lippyp's Avatar
I've recently put a sway bar from a 78 onto my 67 with the dropped brackets from ECE so I would imagine that the reverse would also work. Can't help you on the bagged bit though.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-19-2004, 06:50 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All the way up through 87 trucks and 91 Suburbans will work.
See the FAQ section for an article I did on front sways bars on a lowered truck.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
