Old 10-06-2004, 01:03 AM   #1
TIMSPEED
TIMSPEED's Avatar
Fuel Cell's: What to do with the vent fitting?
You guys that have swapped in a fuel cell, what did you do with the vent fitting? Did you run a line from it to your charcoal canister...or what?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-06-2004, 10:35 AM   #2
corn
You can use the charcoal canister, on my chevelle I just ran a line up above the tank top & curled the line(like a phone cord) so the gas wouldnt slosh out of it...
corn is offline   Reply With Quote
Old 10-06-2004, 10:43 AM   #3
patgizz
patgizz's Avatar
if you plan to race your truck any at the strip you need to install a rollover valve in the vent(not cheap, $32 last time i bought one).
patgizz is offline   Reply With Quote
Old 10-09-2004, 12:02 AM   #4
81shavedtrk
if its aluminum cell it has a rolover valve in it just put a fitting and hose going down to nothing if its plastic put a vent in it and call it a day mine is aluminum
11.98 @112mph Stock suspension and little tires.
81shavedtrk is offline   Reply With Quote
Old 10-11-2004, 08:14 PM   #5
loweredd
www.loweredd.com
loweredd's Avatar
My aluminum one has the rollover vent in it, but the gas smell is obnoxious.
loweredd is offline   Reply With Quote
Old 10-11-2004, 08:54 PM   #6
rage'nrat638
rage'nrat638's Avatar
here's mine.. i close the valve when parked to keep the gas fumes in the tank...
rage'nrat638 is offline   Reply With Quote
Old 10-12-2004, 03:20 AM   #7
lost wages
lost wages's Avatar
hey rat, can you get a better pic of the valve you close, i have a 16 gallon plastic tank in mine and when i open the bed cover its awful, hate to be smoking a cig and blow up the house.
lost wages is offline   Reply With Quote
Old 10-13-2004, 06:29 AM   #8
rage'nrat638
Here You Go.....
Old 10-15-2004, 04:52 PM   #9
81shavedtrk
problem is when in the sun the tank will swell if it has no where to vent the fumes.
Old 10-15-2004, 06:22 PM   #10
bagged81
Signals in the bumper.
bagged81's Avatar
You loose octane points when it is open to the air and I sure he needs all the octane he can get with that truck.
I have mine vented straight down throught the floor of the bed.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 10-15-2004, 06:39 PM   #11
loweredd
www.loweredd.com
loweredd's Avatar
Do you have any pics Jeff?
Old 10-15-2004, 08:46 PM   #12
rage'nrat638
Cool
[QUOTE=81shavedtrk]problem is when in the sun the tank will swell if it has no where to vent the fumes.[/QUOTE
man some people.....
the valve is for parking in the garage !!!!! so you don't blow your family up.....not sitting outside in the sun...
Old 10-15-2004, 10:19 PM   #13
81shavedtrk
[QUOTE=rage'nrat638]
You are right i am dumb. BUT,,, every vehicle vents the gas fumes. If it didn't then they would swell do to heat alone.
Old 10-15-2004, 10:27 PM   #14
rage'nrat638
never had a problem in my garage....insulated.....alway's cooler than outside....
i have had more problem's remembering to open the valve not to pull a vacuum on the tank with my star 500 electric fuel pump...supports upto 2000 H.P. that thing really pumps.....
don't ever want that 1250 dominator running dry !!!!!!!!
Old 10-17-2004, 08:54 PM   #15
81shavedtrk
yeah i had mine plugged off when sitting outside cause of rain and if I forgot to open it, the carb would run dry. But all I have is an aeromotive 150gph and NOS pumps with a little holley 800 (i am poor)
Old 10-19-2004, 07:22 AM   #16
bagged81
bagged81's Avatar
This is the only one that I have of the cell, its not very good. I eventually am going to put one between the rear frame rails. The right side is the feed, obviously, and the left is the vent. The vent dumps about 6 inches below the floor. I dont have any fume problems.
Jeff C.
