Old 10-19-2004, 01:56 AM   #1
apstguy
LED King
apstguy's Avatar
Exclamation New brakes no stop
I got powerslot rotors (BTW 1/2 suburban 2wd rotors will work with 1/2 ton 2wd HD brakes perfectly) New ceramic disc brake pads, turned the drums, and put in new shoes. The truck now barely stops. I didn't mess with the fluid at all. WTH? It doesn't stop and the parking brake doesn't work either! What is wrong? I need to drive the truck tomorrow!!!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 10-19-2004, 07:50 AM   #2
blink32
blink32's Avatar
I can't comment on why your parking brake doesn't work, but your lack of stopping power could be from those ceramic pads. They sound like those expensive ones that take a lot of heat before they grip well. Did you check out the heat range for those pads when you bought them? Did they say that they were good for everyday driving or anything? It could be like the EBC product line of Green, Yellow and Red. Everyday, good for racing/soso for daily, poor for daily but excellent for racing. You might just not be getting enough heat to them to work properly.
blink32 is offline   Reply With Quote
Old 10-19-2004, 08:31 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
You need to read this info on -Bedding in new pads and rotors It makes a huge difference in how your brakes will perform....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-19-2004, 10:32 AM   #4
apstguy
LED King
apstguy's Avatar
They are the ceramic pads from Raybestos - so nothing that special. Maybe the rear drums aren't self adjusting and the combination valve won't let the disc engauge all the way??
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-19-2004, 11:12 AM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
sounds to me like there is something wrong with the rear shoes causing this problem because of th emergency brake not working.
Perhaps the e-brake cable is hung up.
Also did you open the master cylinder reservoir?
Might it have too much fluid in it causing pressure from compressing the wheel cylinders and caliper pistons?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 10-19-2004, 07:14 PM   #6
apstguy
LED King
apstguy's Avatar
The self adjusting drums were not self adjusting causing the shoes to not contact the drum - the combination valve prevented the disc from engaging before the drums. I fixed it this morning. I'm going to have to fix the drums though. Drum brake are the scourge of all evil. The brakes get stronger and stronger as I drive it. Now all I have to do is put on the stainless steel brake lines and flush the fluid (I look at the master cylinder and the fluid is almost black and has flakes in it - yuck!
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-19-2004, 07:23 PM   #7
DennyB
DennyB's Avatar
Tyler,
Even though you have self-adjusters on your drums, you still need to adjust them when you put on new shoes.
There should be a rubber plug on the back of the backing plate adjacent to the "star" of the self adjusters.
Remove the plug so you can get a screwdriver in to turn the star.
With the wheel in the air (on jack stands with wheels chocked) and truck in neutral, turn the wheel and adjust (turn) the star till the shoes start to rub. Repeat on the other side.
They will never come up to full pedal unless you do this.
Denny
Old 10-19-2004, 07:31 PM   #8
apstguy
LED King
apstguy's Avatar
Some of the teeth on the star ajusters on both sides were broken. The parking brake support springs on both sides also broke. I fixed them for now (glue!) But I'm going to get new ones.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-19-2004, 08:38 PM   #9
white82
White 82
white82's Avatar
i usually adjust the shoes out till the drum barly rattles on the drum as im putting it on/ and then i would adjust the emergency brake underneath i would bleed the brakes 2
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6
white82 is offline   Reply With Quote
Old 10-20-2004, 11:56 AM   #10
corn
Back up & hit the brakes hard a few times will usually set the rear adjusters. Easy thing to try too...corn
corn is offline   Reply With Quote
