#1 | ||
monsoones truck flooding..
1st major rain of the season today and it came with a fury! The streets had like 2 foot water and my truck kept flooding out. How can I stop/prevent this from happening?
its all about the +6 inches
don't drive it in 2 feet of water?
You need to determine the actual reason it was stalling. I have driven through water that was over the bumper on my GMC last spring...it was coming in through the doors, my feet got wet...kinda ticked me off. But I forgot all about it when i tried to stop. ($ wheel drums filled with water don't stop very well) After deep water fording, you NEED to inspect your fluids. Check your tranny, engine, and your diff. if you have an open air filter, check it too. Once the fan hits the water, it splashes it and it sprays everywhere. My air filter was the only thing that was ruined in my stupidity. How was it running, how was it stalling...was it missing like a plug wire came off, or would it just stall like you turned off the ignition? |
#3 | ||
she sputtered a secnd or two then died. Started again afetr about 30 secs of people beeping @ me..LOL! I may do that again for the hell of it to see how many people will beep..lol
Rich
hmm...
sounds like you were getting water in it. Not enough to hydrolock, but enough to lean out the mixture a lot.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
Professional Grade
If you plan on going through deep water like that, make sure that you have some sort of a snorkle style air cleaner on (stock style, not open air element) and have it aimed towards the back of the motor, this way it won't suck up water. Take her real easy going through the water, your truck isn't a power boat, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
English Chevy Owner
If you have to drive through deep water (as I'm sure a lot of the 4 wheelers on here will confirm) you want to be going at a speed that pushes a small bow wave in front of you, this stops the bulk of water entering the grille, it's not dead idle slow but not fast. If it's a short distance you can drape a plastic sack/cardboard etc in front of the grille to stop water getting in (trap it under the hood and around the front bumper if possible) or disconnect/remove the cooling fan if it's engine driven...but only for a short distance. Water may have entered the diff as when a diff full of hot oil hits cold water it contracts causing a vacuum, and will pull water in via the breather, that's why most off roaders lengthen their breathers to above water line. Spray some WD40 over the electrics/dizzy/plug leads before and after.
And always make sure you know how deep the water is before going in! I have some experince in this as I used to off-road quite a lot in various vehicles and hopefully will again soon as i am currently searching for another 4x4, sadly not a US vehicle although the parent company is GM, I want an early 90's MK Isuzu Trooper LWB 2.8TD.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission Last edited by Lippyp; 10-20-2004 at 05:26 AM. |
Black 72 Chevy
I like the rain, but I dislike the traffic it causes. People don't slow down. Its been raining for the last 3 days.
I'm mad, all you guys getting rain and it's like the Sahara down here!
English Chevy Owner
It's been raining here for the last three months!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#10 | ||
[Quote]Certainly cleans your block off too the water hits it and boils almost immediately, boils a lot of the oily stuff off, lol[Quote/]
...LOL!
This is my first post on this board and had to throw in my $.02.
I had similar problems with a 68 Chevelle Malibu. I found that inside the distributor cap was getting wet. The water was spashing off of the firewall. I first used grease to help prevent most of the water then went HEI. |
