Cruise control
Anyone have a recommendation on an aftermarket cruise set-up for our trucks?
Dan
'68 Chevy LWB Fleetside 3/4T, 454/T400, PS, PB, PL, HEI, Dynomax Ceramic/Flowmasters, Oak/Stainless Steel bed, 90% Rest. '97 Lexus LX450 (FZJ80 Land Cruiser in disguise) Factory F&R Lockers '97 Camry DD w/Cleveland Browns sticker |
Gotten zero response on this one. Has anyone had any bad experiences with a particular brand?
Lovin' Life in Miss.!
Sorry for not responding. I put one in a 75 like 10 years ago. It installed well, worked well but had a fugly control panel. I got it from JC Whitney. That's about all I recall. Oh, I think it worked off of engine vacume instead of magnets for speed control.
Edit: I found a post by 69 1/2 six pack bee. He had posted a pic and had an aftermarket cruise control mounted to his turn signal switch. Maybe you could pm him.
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 10-12-2004 at 08:35 PM. |
I have an Equus, but they don't make them any more. If you don't have a lockup converter, get one that uses a speed sensor on the driveshaft. If you use ignition pulses as a speed sensor, it will hunt around due to converter slippage.
Dakota Digital makes one that doesn't operate off of engine vaccuum. A little pricey though. Good luck and keep on truckin'......Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake 600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash |
I have an Audiovox cruise control I bought from JC Whitney for less than $100 on sale.
I mounted the not-so-pretty controller knee-knocker style below and to the right of my steering column. The Audiovox unit has several ways you can program it to sense speed. When I installed it my truck had a manual transmission. With a manual you can use a tach signal because there is no slippage when the clutch is engaged. However I was planning to and did swap to a th350 so I put the magnet from the kit on the driveshaft which gives the cc a speed to keep constant. One of the best upgrades I have done to my truck.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
![]() Join Date: Mar 2000
Try Rostra. Very versatile and work really well. I believe they used to be called Hayes Dana but changed their name.
Saskatoon, Saskatchewan Canada |
Sting Ray - Thanks for the tip. Found a distributor for Rostra. Will post results after installation.
Dan
![]() Join Date: Dec 2002
I also am using a Rostra speed control........
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
you could always just put a brick on the gas pedal? right? j/k but that would be a great upgrade for any old truck.
454 runs on unleaded as well as natural gas orange white two tone paint so many plans for the future ![]() |
rostra and audiovox are one in the same! I sell them and have installed them on several newer cars but I always use the elctronic type which needs the vehicle speed sense. I was displeased with the last one I did but it wasn't the cruise's fault it was the gutless S10 w/4cyl standard shift trans. They can be a pain to install but I have never had to warranty one after it was installed!!!!!!!!!!!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
