10-21-2004, 02:42 AM | #1 |
Removing ignition on 72
How do you remove the ingition itself on the 72's dash? Ive got everything else but it off and its starting to annoy me. Thanks.
1972 Chevy C/10 350/200r4 |
10-21-2004, 03:28 AM | #2 |
there is a little hole on the front of the switch. put the key in and turn it to the right to the acc. position. next push something like a paper clip into the hole you will fell it depress then turn the switch counterclock-wise until it stops, you may have to do this several times until it is freely moving. Then using the key remove the switch through the front of bezel.
72 GMC sierra 3/4 ton 402 bb 68 GMC 3/4 ton 2010 camaro rs: daily driver |
10-21-2004, 07:22 AM | #3 |
Use some liquid graphite to help lube the unit (Don't get it on your cloths, will stain)
Don't use WD-40 or oil based lubes, the oil just draws dirt and dust into the locks....then you have all sorts of problems.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
10-21-2004, 04:47 PM | #4 |
Straight jacket required
What if you don't have a key???
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
10-21-2004, 05:34 PM | #5 | |
no key
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
