i love summertime
whats the biggest size tire i can go with--no lift
hey guys im looking for some tires to put on my 71 gmc 4x4 i just bought, how big can i go without rubbing? i dont plan on any crazy 4 wheeling, mostly just a daily driver and a bit of fishing/camping, i guess i should also add that im planning on getting some ralleys, so the rims will be 8 inches wide
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
I have 33x12.5's on 15x8" rims with 3.73" BSing on my truck, I have 3 leaf springs in the front also and that raises the front and makes the truck sit pretty level with the rear, no rubbing as of yet, but it hasn't been off-road either, seems like may rub with lots of flex and no swaybar.
I think 32x11.5" tires would clear with no rubbing, 33x12.5's may rub some, just depends on how low your truck is sitting, and wheel combo and the actual measurement of the tire.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
![]() Join Date: Apr 2003
yep, 33 12.50's fit, barely, on my truck, make it look pretty mean
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
i love summertime
griesel- got any pics?
thanks
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have 32x11.20x15 's on my blazer and ton's of room or so it look's like anyway's never had em rub....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
i love summertime
right on french-
can you guys post some pics of your trucks so i can get an idea of what they look like with no lift and the tire sizes mentioned above? thanks
Geared for Collision
heres my truck before i dissasembled with no lift and 33 x 12.5 tires, hope it helps.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
The Blazer King
I think 3/4 ton's sit higher. A 1/2 ton should be tucked up nicely.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
i love summertime
cool guys, thanks
i had 33x12.5's on my stock 69 K-20 and there was plenty of room...
right now (actully today...) i put 33's on my 71 K-10 (factory HD front springs) and they fit, there close in the front, but they dont rub. i havnt been off road yet... i bet they'll rub then. i was going to put helper springs in the front and maybe a 2" block in the back... just so the res a little more room and... on my friends 86 K-10 we put 35x14.5 "gumbo monster mudder" (looks like a knock off of tsl's) and they fit... but the front fenders rub if he turns hard... man, do those things throw mud!!! we ran water in his field for about 1/2 hour, till it was real muddy and went and tore thorugh it...it was sweet Last edited by BurnoutNova; 10-19-2004 at 01:39 AM. |
heres my stock 71 K-10, with 33's on it, definately sits shorter than a 3/4 ton. it soesnt rub, but it looks like it could if i hit the right pothole or somthing. i think my truck needs about 2" lift and then just do the body and it'll be good enough for daily drivin.
Fetzer Valve Technician
Here is my 72 which has no lift and 32x11.50x15's on it. It is saggy in the back, due to my 400 SBC in the bed.
1972 Chevy K10 SWB |
heres my 85 with 1 1/4 ton CUCV springs in front and stock 1/2 tons in the rear, makes the truck sit level with the 3 leaf CUCV springs in the front.
i love summertime
hey guys, i ended up going with some 31x12.5s
i know they are smaller but on the ralleys they look sharp, and i dont have to worry about any rubbing issues sorry about the very dark pic, ill get good ones on saturday
#15 |
what kind of tires are they? Only 31x12.5" tires I know are pro comps, but I don't look around too much, I thought about putting some 31x12.5's on mine myself.
