Old 10-22-2004, 01:08 AM   #1
mdazb
mdazb's Avatar
Cool Power steering pump bracket
Have a 350 with the alt. mounted on the driver's side on the engine. A friend of mine gave me a P/S gear box w/lines and pump. Need to find out where the pump mounts. Do I need to relocate the alt to the other side of the motor or, does the p/s pump mount under the alt? Also anyone know where I can get NEW brackets?
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 10-22-2004, 01:52 AM   #2
ED Bensley
I have a 72 C-20 with alt on driver side and the power steering mounts under it. The bracket has three blots -two in the frount and one is on the motor mount.
ED Bensley is offline   Reply With Quote
Old 10-22-2004, 07:20 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here's a couple of pictures of the two different types used on these trucks.
Like was said above, they do mount on the driver's side of the engine, below the alternator assembly.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-22-2004, 09:18 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What year was the brackets supposed to be from? I'll bet it is from a 70 & up car or 73 & up truck and won't work with your short pump or dvr side alt.
Old 10-22-2004, 11:02 AM   #5
mdazb
mdazb's Avatar
Thanks for info and pix, what year range should I be looking for then so I can get this hooked up. Also, If I have man steering now, other than the pitman arm, rest of the steer. linkage remains the same for the P/S convert?
98 HD Fatboy
05 Honda Element
Old 10-22-2004, 12:10 PM   #6
kaycee
kaycee's Avatar
I got mine from a mid 60's Impala,it was the same set-up as the 1 on my 70 which is drvs side mounted alt allso.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
