Old 10-10-2004, 08:49 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Wanted- dually or dually parts
I want to build a dually truck. I only want the short wheelbase one though, not the 157 incher.
I'm looking for either suspension and brake stuff or I'd buy a whole truck if the deal was right.
I have a trailer and can travel a reasonable distance. I'm in far North Texas, so Oklahoma, Arkansas, Louisiana, or maybe even lower Kansas is in reach.
Tell me what you have, no parts too big or small.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-10-2004, 09:17 PM   #2
GSFMECH
On the road
GSFMECH's Avatar
Tx,
Don't know if any of this will work but I have what's left of a 75 gmc 1 ton Cab and Chassis truck. The entire disc brake front end is still under it but it has a leaf sprung 14 bolt (GM?) rear end under it. I think all the brake stuff is gone off the rear but would have to check. Problem is I'm overseas now and won't be home for 2 1/2 more weeks. It would be cheap if you come pull what you need, or take the whole truck. Not much left of it anyway and no title.
Mike
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 10-11-2004, 09:18 AM   #3
Tx Firefighter
GSFMECH, I sent you a PM. Let me know when you get everything figured out. I may be interested in driving out there.
Old 10-12-2004, 01:27 AM   #4
GSFMECH
On the road
GSFMECH's Avatar
PM recd.
I will check on all of my stuff and see what's left when I get home and shoot you some photos. I am in Trinidad (I work on an offshore drilling rig). I should be back in the States the 27th or 28th.
Mike
Mike
Old 10-19-2004, 10:48 PM   #5
True Grit
Why Buy New?
True Grit's Avatar
i found a 72 1 ton wrecker in a local paper . will get back to you asap with ph#. asking price was $2000. also know about a 72 1 ton with a flat bed,no eng,has 4 spd,pretty straight.cheap imo.
'71 GMC 1/2 Ton LWB
'71 Chevy 3/4 ton Longhorn
True Grit is offline   Reply With Quote
Old 10-20-2004, 07:47 AM   #6
Tx Firefighter
I'd definitely be interested in hearing about the flat bed truck.
Old 10-20-2004, 08:46 AM   #7
True Grit
Why Buy New?
True Grit's Avatar
pm sent
'71 GMC 1/2 Ton LWB
Old 10-20-2004, 09:33 AM   #8
JDL
JDL's Avatar
how about a 75 or so with a flat bed and 454? I don't what year it was but he wanted around $1000.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 10-20-2004, 10:58 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Would you consider 133" short? I'm getting a 72 c30 with that wheel base. I plan on pulling the cab and dog house. But will have the 2 piece driveshaft and what not left over as well as the front suspension and frame. I'm not sure about the rear end, it might end up under my 70. Will keep you in mind as it comes apart.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-20-2004, 11:21 AM   #10
matt67350
matt67350's Avatar
Did you still want the 72 I have?
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 10-20-2004, 07:42 PM   #11
True Grit
Why Buy New?
True Grit's Avatar
'72 1 ton wrecker,pto winch,gin poles . said it was pretty straight ,will run and drive.located in sperry,oklahoma.918-288-7080.ad in paper said $1995.
'71 GMC 1/2 Ton LWB
Old 10-20-2004, 11:50 PM   #12
longhorn71
longhorn71's Avatar
I have a 67 dually for parts all the front suspenion is there open to offers
longhorn71 is offline   Reply With Quote
Old 10-21-2004, 05:33 PM   #13
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Hey longhorn71, did you ever check about the front dually spacers and the west coast mirrors? Never got a PM back from you.
Thanks man
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 10-22-2004, 06:02 PM   #14
True Grit
Why Buy New?
True Grit's Avatar
tx firefighter, pm me your e mail address for pics
'71 GMC 1/2 Ton LWB
Old 10-22-2004, 07:27 PM   #15
Tx Firefighter
True Grit, PM sent w/ email address.
Old 10-22-2004, 08:11 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LOCAL SALES LOT, 70 1 TON SWB W/ FLAT BED V8 AND GRANNY 4 SPD., $1050.00
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-22-2004, 09:03 PM   #17
junkyardjohn
junkyardjohn's Avatar
Originally Posted by Tx Firefighter
I want to build a dually truck. I only want the short wheelbase one though, not the 157 incher..
MY 69 C-30 WRECKER IS A 133" WHEELBASE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
