turbo enthusiast
suspension question
Which suspension would be better for carrying a load of 500lbs or towing a trailer that weighs 1500-2000lbs. The 2wd coil suspension or the K5 leaf spring suspension? I don't really need a 4x4 but I need the truck for work.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
The LuvShack Garage
![]() $500.00 Link" Has A 250 Inline 6, 350 Turbo Tranny, 4:10 Gears, Custom Class 5 Hitch (stronger Than A 4) And I Pulled 6000 Lbs. To Memphis And Back. (2.5 Hrs. Round Trip) Oh Yea, She Has Coils And She's Also Slammed Ridin On The Snubbers All The Way Around, Pulled Fine. ![]()
#3 | |
turbo enthusiast
![]() What were you towing round trip that weighed 6000lbs? ![]()
#4 | |
The LuvShack Garage
![]() ![]() 1967 SWB FLEETSIDE WITH A 400 SB AND POWERGLIDE ( COMPLETE TRUCK ) 3 350 ENGINES / 1 400 ENGINE / 1 350 TURBO TRANNY / 7 BELL HOUSING'S VALVE COVERS / CARB.'S / 3 SETS OF HEADERS / AND SOME SMALL STUFF ( ALL OF WHICH WAS LOADED INTO THE BACK OF THE 67 PICK-UP ABOVE ) DUAL AXLE HD BOXED FRAME 8 X 20 DOVETAIL PRESSURE WASHING TRAILER WE UNLOADED TO PUT MY STUFF ON, IT WAS SO HEAVY IT USED 2 5/8 BALL ( SUPER CHEVY IN MEMPHIS 2001, BURNED 5 QUARTS OF OIL ROUND TRIP )
turbo enthusiast
and that 6 cylinder pulled all that? Must not of had any hills.
Junior Member
i would say coil sprung suspension, less axle wrap than leaves, but 500 lbs isnt too much either way. if you use a 'soft ride' style lift leaf spring the wrap gets worse than you would think.
good luck. tommo |
Where's my beer?
Leaf springs....
Leaf springs are 100% better than a coil spring suspension to tow, I used to have a C-10 with coils and whenever I towed with it always seemed to be moving around like crazy and it wasn't that stable and it even had auxiliary leaf helpers, now my 3/4 ton with leafs doesn't do that, that's why I prefer the leaf over the coils for towing.
That axle wrap that tommo describes might happen if you had a race truck with a lot of power (it would be an empty truck) therefore making your rear axle hop around like crazy, that's when you would have axle wrap, but when towing you have a load pushing down on the back of your truck so axle wrap wouldn't be as big of a problem here, just my .02
Paul How do you make the invisible, visible?.........You take it away. |
