Old 10-23-2004, 07:47 PM   #1
sinister72
sinister72's Avatar
how to remove rear u bolts?
I know this seems a simple question. But does anybody have a trick on removing the rear u bolts on a "72" Have tried a strong arm and a 3' cheater bar, but only got a sore back!
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 10-23-2004, 07:57 PM   #2
LONGHAIR
Fire.........Heat. You can either heat the nuts or cut the u-bolts and put in new ones.
If you don't have a oxy/acc torch to cut with a common porpane torch will do the heating part.
LONGHAIR is offline   Reply With Quote
Old 10-23-2004, 09:03 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
cut em! I use a die grinder with a cut off wheel.
Keith
Convert to disc brakes.
Old 10-24-2004, 03:54 PM   #4
Joe67
67 is sold
Yep - when disassembling my wrecked 67 frame, I cut the bolts
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-24-2004, 04:20 PM   #5
Inthuwind
Straight jacket required
Inthuwind's Avatar
a good method is to heat em up and theyll come right off. I did mine that way and it was easy.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 10-25-2004, 09:07 AM   #6
raggedjim
raggedjim's Avatar
I tried heat(oxy/ace) and a 10' cheater and still ended up cutting the bolts with a die grinder.
Be careful, there's alot of stress on those u-bolts and when they give it can scare the crap out of you...
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 10-25-2004, 09:52 AM   #7
boraxman
Keepin an eye out
boraxman's Avatar
I also ended up cutting mine off.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-25-2004, 10:54 AM   #8
Blue Beard
Blue Beard's Avatar
Guess I've had good luck...
Just sprayed mine with penetrating oil several times...used a cheater bar, came right off.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-25-2004, 10:00 PM   #9
sinister72
sinister72's Avatar
HEY HEY I got them off,after cutting with a die grinder,and they do pop and scare the crap out of you the first time! Live and learn!!
Old 10-25-2004, 10:00 PM   #10
chevytruckfan
chevytruckfan's Avatar
A good 1/2" 500ft/lb torque air impact gun usually does the trick for me.
chevytruckfan is offline   Reply With Quote
Old 10-25-2004, 10:56 PM   #11
raggedjim
raggedjim's Avatar
Yeah, I've got knots on my head from that popping noise...
Old 10-30-2004, 03:29 PM   #12
inline6Bill
A classic GM kinda guy
An old trick I used to use on "stubborn" bolts:
Heat the offending bolt and nut with a torch, then cool the bolt down with penetrating oil. Works great, especially on those stubborn exhaust manifold bolts.
Old school rap music: a dual exhausted GM 6 with no mufflers.
"If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s.
"I did. They are called Classic GM pickups !!!"
inline6Bill is offline   Reply With Quote
