Old 10-25-2004, 11:38 AM   #1
'70_402
'70_402's Avatar
Valve Covers
Has Anyone Used Or Have Pics Of These Valve Covers On Thier Trucks?? I Am Thinking About Them But 300 Bucks Is A Little Steep.
'70_402 is offline   Reply With Quote
Old 10-25-2004, 11:51 AM   #2
barn9
Half a bubble off!
barn9's Avatar
They are good lookin' valve covers, but $300 is a LOT steep!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 10-25-2004, 11:53 AM   #3
Bram
Broke
Bram's Avatar
Yeah I just posted some updated pictures here,
http://67-72chevytrucks.com/vboard/s....php3?t=124954
I don't remember where I bought mine, but they were just over two hundred bucks.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 10-25-2004, 12:15 PM   #4
'70_402
'70_402's Avatar
Hey Bram, Did You Check Your Brake Booster Clearance Before You Got Those Valve Covers? I Have Some Smaller Ones On Mine Now And I Bang Them Up It Seems Everytime I Take Them Off And On. I Am Wondering If They Will Fit On Mine Also? By The Way They Do Look Freakin' Sweeeet!
Old 10-25-2004, 12:18 PM   #5
Bram
Broke
Bram's Avatar
Thanks, and Yep, I changed over to a hydro boost system, it gave me a lot more room.
Old 10-25-2004, 12:46 PM   #6
'70_402
'70_402's Avatar
Bram, If You Could Remember Where You Got Yours That Would Be Sweet Because The Cheapest I Have Found So Far Was $315!!!!
Old 10-25-2004, 12:47 PM   #7
gregfull
gregfull's Avatar
I've thought about putting those on my 502 too, they really look good. Hey Bram, what is a hydro boost? A smaller booster and master cylinder?
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 10-25-2004, 12:55 PM   #8
Bram
Broke
Bram's Avatar
70'_402, I'll try to find my receipt tonight after work, and let you know.
gregfull, the Hydro Boost Power Brake System is a booster that works from hydraulic fluid pressure produced by the power steering pump. Here is a picture similar to my setup.
Old 10-25-2004, 03:39 PM   #9
'70_402
'70_402's Avatar
bram, don't mean to ask 20 questions but, where did you get your hydroboost setup? i heard they were on the diesels but is there a setup that will bolt right on to our trucks... i am not familiar with that setup. is it worth it if i have disc's up front and drums out back? what are the advantages?
Rick
Old 10-25-2004, 03:56 PM   #10
meathead95
computer illiterate
meathead95's Avatar
i am wanting those covers for the bb in my 2wd blazer. do they make a matching air cleaner?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 10-25-2004, 04:20 PM   #11
Bram
Broke
Bram's Avatar
Thumbs up
70'_402,
Where did you get your hydro boost setup?
1. I got the Hydro Boost from a 96 Chevy 1 ton 4x4.
I heard they were on the diesels but is there a setup that will bolt right on to our trucks?
2. They came on gas and diesel trucks, and yes it will bolt up to our truck's with some modification.
Is it worth it if I have disc's up front and drums out back?
3. I really don't know but, I have four wheel disc brakes all the way around that’s why I did it.
What are the advantages?
4. The reason for adding the hydro boost was to provide for a firmer pedal feel, while obtaining additional braking performance by adding more line pressure than what was being achieved with the stock vacuum booster for my four wheel disc.
Hope thats helps?
Meathead95,
I haven't seen a matching air cleaner? That would be cool!
