Old 10-07-2004, 08:40 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Autometer Guages
Is anyone using Autometer guages that actually fit recessed in the stock cluster. I know 2 1/16 Pro Comps fit recessed in the dash but I was wondering about the tach and speedo. I have seen it done but cant remember when or where. Anybody got any pics.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 10-07-2004, 09:22 PM   #2
1972ChevyCheyenne
Never Seen this in person, picture look good though.
http://classictrucksweb.com/tech/cl_0311_6772dash/
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 10-07-2004, 10:16 PM   #3
Blue Beard
Blue Beard's Avatar
Good article, wish they told how to wire it to the stock wiring harness.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-08-2004, 12:45 AM   #4
68plus4sub
68plus4sub's Avatar
I have just completed putting my Auto Meter Pro-Comp Ultra Light guages in my Dash Bezel. I used the 5" electric speedo and tach, and the 2 5/8" clock, voltmeter, fuel level, and mechanical temp and oil pressure of the same size. I mounted them on the outside of the bezel (in the hole from the front) because I really like the ring on the guage, and I felt mounting them from behind put them to far back in the dash. It took me some time to decide, because both ways look good, I just preferred seeing the cool silver ring.
I had to cut the lower holes slightly larger, make an ABS panel for the clock which went in the center upper hole, and wrap the 5" guages to make them larger around to fit more snug in the large holes.
If I can get a picture, I will be glad to post it here for you to check out. I had the 'burb painted a metallic silver, which really looks awesome with the silver faced guages.
Also, I found the "key" to the stock wiring harness in the Haynes (I think) shop manual. It tells what each color of wire coincides with. So then, I just clipped the wires, soldiered(sp) them, and put heat shrink over them.
Auto Meter recommends in line fuses for the tach, electric speedo, and clock, which I also installed.
Put LED's in the turn signal holes into the same ABS piece that a mounted to clock in.
Took plenty of time, but they work and look awesome, and they are in there "right".
Electric Speedo required a sending unit to attach to the tranny where the cable used to go.
PS - The needles on the gauges almost glow, you can see their position at a glance.....coooool
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 10-08-2004, 12:53 AM   #5
sdkid
Hey 68plus, post a pic. I want to do this also. Right now I've got a sun super tach in the factory tach location. I want better gauges though.
sdkid is offline   Reply With Quote
Old 10-08-2004, 12:58 AM   #6
68plus4sub
68plus4sub's Avatar
I'll work on it..........do you pronounce that PEER, South Dakota? Just curious!!!
1972 Porsche 914
Old 10-08-2004, 03:01 AM   #7
Mudder
Mudder's Avatar
Something like this?
Pretty easy mod.
Mudder is offline   Reply With Quote
Old 10-08-2004, 02:00 PM   #8
flip66
flip66's Avatar
Gauges
I just put this dash in my truck. Still has the stock Speedo and fuel gauge, I did not do the work but there was no cutting of the dash on the bottom. they just cut the clear plastic gauge facing off and slid the gauges throught the front. I can get better pictures if you want them
flip66 is offline   Reply With Quote
Old 10-25-2004, 10:29 AM   #9
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Flip, I would like some closer pics please.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-25-2004, 06:25 PM   #10
flip66
flip66's Avatar
pictures
pictures
Old 10-25-2004, 07:32 PM   #11
RON WOODGEARD
Resident Young Old Dude !
How soon we forget........ Look in the FAQ page and you will see my complete install info, with pictures.....
RON WOODGEARD is offline   Reply With Quote
