Old 10-25-2004, 05:19 PM   #1
diggy
Need a Tech. Ques. about 14 bolt rearends
What kind of 14 bolt can you get on a 1970 C-20 2wd? I saw one at the yard while looking for another part, and since i had no tools on me to measure the diameter, i am wondering if it could be a full floating rear or would it be a semi floating rear. It is 8 lug so i assumed it was a full. The yard wants $350 for it. Is that a fair price to pay?
thanks
joe diggy
72 Suburban Ambulance 4x4 - 350, T-400, NP205, A/C, PS, PB, 4 wheel disk, 4" lift 33" tires
diggy is offline   Reply With Quote
Old 10-25-2004, 05:28 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
They didn't put 14 bolts in these trucks, '73 was the first year if i remember right. Stock rear would have been a Dana 60 (odd shaped cover, 10 bolts) or a HO52 (round cover, also 10 bolts i think). The 14 bolt rear, which could have been swapped in has 14 bolts on the cover. The semifloating rear has a more oval shaped rear cover, while the full floater has an odd shaped cover, kinda like the Dana 60 rear. Also, the full floater will have exposed hubs at the end with a circle of bolts on them, portruding from the wheel stud area, beyond the wheel studs.
For a axle ID guide, go here:
http://www.offroaders.com/info/tech-.../axlefacts.htm
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-25-2004, 06:55 PM   #3
diggy
thanks for the ID guide
it definitely is a 14 bolt and i am 90% sure it is a full floater....that being said is $350 a fair price to pay.
