10-25-2004, 10:35 PM | #1 |
Professional Grade
Cruise modulator thinger
How does this thing work?
I've got my whole cruise setup working less that stupid fender peice. I bought a new one from the wrecking yard, but it's coil must be burnt out or something as it doesn't work at all. I can hear the main relay click when I press the button, but all it does is simply floor the truck outright, even if I do it at a complete stand still in park. Does anyone know how a guy can fix it, I took it apart, but I don't understand how it works... Or does anyone have one? Its from an 80.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-25-2004, 10:52 PM | #2 |
I have one off a TPI Let me know if you need it. I even have a enormusly long cable for it .. I had gotten it for my cruise swap since my cruise setup came from a camaro But managed to get a cruise servo /cable off a carburated camaro.
I really like mine being on the fender as opposed to next to the distributor like these trucks come with. |
10-25-2004, 10:56 PM | #3 |
He's got mean nasty FANGS!
Just get a remanufactured one from a parts store, cruise is one thing to not mess around with IMO. You can get a reman unit for under $100US.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
10-25-2004, 11:39 PM | #4 |
Professional Grade
Everything works but the fender mounted unit -- but I am still interested in the TPI cruise system, as I'll be going with a TPI later.
I am getting the system going so I can sell it, as I won't be able to use the factory setup. But I wouldn't mind getting a cruise setup from a Camaro to run cruise with my TPI though
