what year van columns work
can you use any of them with the key on the dash or just certain years?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Pretty much any of them with the key in the dash. I think they quit in 1982, but not positive on that.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I did a search and someone mentioned motor home columns is this the motorhomes with the van chassis or just any early one with gm column?
Got Light Emitting Diode?
you can use any van tilt 73-early82 then they switch to in the collum. i think the earlier collums have the horse shoe plug still and the later ones have a flat plug. but GM sells an adapter i heard. TxFirefighter has a motorhome tilt in his truck (i belive) but i think it would be easier to find a van tilt than a motorhome tilt.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Yes, I have the motorhome tilt in my truck.
its all about the +6 inches
72 - 81/early 82
There is another variable too, the early van tilts...normally the ones with the horse shoe shaped plug, will have a long shofter handle...like the stock non tilt in the truck. If you have inbstalled a smaller than stock wheel, the shifter looks kinda goofey...the later van tilts have a nice shorter shifter. |
thanks guys
