Old 06-24-2002, 04:14 PM   #1
Low69CST
Has anbody made a speaker box to replace your gastank?
I've got my tank out of the cab, now comes time to start building a speaker box. It will probably be 2 boxes. Each with multiple cavities. Total i'll have 2 12" subs, and a 5.5" or 6.5" mid and a tweeter. Has anything simular to this been done by anybody? Oh yeah, it has to house 2 amps too.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-24-2002, 04:23 PM   #2
Smooth68
Smooth68's Avatar
I haven't made any for the 67-72's but I've built a ton for the 73-98 years. Most all the ones I've done were the solid one-piece style with some cool recessed areas for amps and such. I personally don't like the mids and tweets to be behind the seat. It seems to sound 100% better with the mids and tweets up front for staging purposes and just have some subs in the rear, since bass is not a directional sound. Good luck!
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 06-24-2002, 04:42 PM   #3
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
this is a pic of the center console my granfather built for my truck it has 2 jensen 6's in it and an FM modulated 10 disc changer, it mounts to the flush back wall i built which houses 2 Rockford Fosgate 12's the amp and a linear will be under the seats while a custom autosound stereo will fill in the holes in the dash and a small cobra CB will go in the console too.
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 06-24-2002, 04:46 PM   #4
69&72Bowties
I have two boxes behind my seat with 2 12's in them.. I also built some corner panels to fit on the back sides of the cab with a tweeter and a 5 1/4 inch midrange..
It really wasnt that hard....
69&72Bowties is offline   Reply With Quote
Old 06-24-2002, 06:11 PM   #5
XXL
Señor Member
XXL's Avatar
Re: Has anbody made a speaker box to replace your gastank?
1) You're going to run out of air space reeeaaallly fast, especially every time you sink an amp in it.
b) Put the mids and highs somewhere else. All they do behind the seat is squawk at you. Most of the audible frequency range is highly directional.
III) I built a "shoehorn-in" box years ago. Basically (I'm leaving out the fact that it's a LOT of work), tape some newspaper (several layers) onto all the metal surfaces back there, cover that with trash bags, then get you several cans of spray foam. Let the stuff fly until you have a big giant chunk of foam that takes up the whole area (you can control the frontward movement with a piece of plywood laying at the angle where the seat will rest). When it's done expanding, cut it down the middle top to bottom and pull both pieces out. Lay fiberglass cloth across the backs tops and bottoms of the mold you created. Then work in a wood front panel with all your amp sinks in it. Like I said... lots of work, but you'll gain as much as 1 ft3 extra air space... a necessity with bigger woofers.
Phew...
Kenneth
XXL is offline   Reply With Quote
Old 06-24-2002, 08:54 PM   #6
ckhd
ckhd's Avatar
If you replace your gas tank with speakers, you won't be able to get very far. I think the fuel capacity of the average speaker is less than a gallon...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-25-2002, 09:32 AM   #7
69&72Bowties
Well the panels I built to go in the cab corners do a great job of adding fill to the sound. Most of my sound come from the dash speakers...
I just have to custom built boxes behind my seat.. I dont have any squeaks or rattles... my amps are under my seat....
I could send you some pictures of mine setup if you would like?
Bryan@ideamill.net
71 Chevy Custom 20 Suburban
69 Chevy Camaro
